Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-18-2004, 01:30 PM
bytech bytech is offline
Camry 98 check engine P0125 & P1135
I'm having error code P0125 means Insufficient coolant temperature and P1135 means Air fuel sensor heater circuit response. These codes were scanned by my Lap Loger on my car Toyota Camry Le 1998. Please help!!!.
Old 12-18-2004, 10:10 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Camry 98 check engine P0125 & P1135
If your car is not getting up to operating temperature reasonably quickly, replace the engine thermostat.
Also sounds like your A/F ratio sensor is bad. Check the connection to the sensor. If the connection is good, replace the sensor (the one in front of the cat. converter)
http://www2.autopartsauthority.com/p...l+Ratio+Sensor
Old 12-20-2004, 10:53 AM
Thanks a lot Brian. I wll do that and inform you if it fix the problems. Merry Christmas and Happy New Year.
Old 12-20-2004, 05:40 PM
Brian R.'s Avatar
Resident Chemist
Merry Christmas to you
