wont start
I have 97 chevy blazer, it's wont start, but I did check spark, ign modules,gas, battery, starter, and use EZ 6000 scanner tool to scan the system, but the scanner found not thing...engine turning but still wont start.... NEED HELP PLEASE!!!
THANK YOU!!! |
Lets see.. 97 blazer, won't start. The first thing that comes to mind is the ignition switch. It is a real problem for these blazer's. search this forum for more horror stories on them. If it doesn't cure your problem, it will be something that will save you money later (like when you breakdown on the side of the road like me and have to get it towed)
Good Luck. |
Re: wont start
Ignition Switch
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: wont start
Also check for fuel pressure at the shrader valve. Do you hear the fuel pump kick on when you turn the ignition to the RUN position?
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: wont start
if the switch is bad sometimes the fuel pump won't get power so you might not here it
Re: Re: wont start
do you think maybe ignition switch. i didn't check it out yet thank you for your reply and suggestion i appreciated |
Re: wont start
A bad fuel pump won't show up through the ECM... What is the pressure at the shrader valve? It should be 56-60 at start, 61-65 at running
Re: wont start
Actually, a 1997 should be 60-66psi with the key in the ON position and the truck not started.
!996+ requires a little more pressure and could be the reason they are so sensitive to a lack of fuel pressure.
