Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 12-18-2004, 09:38 AM
jpoth4563 jpoth4563 is offline
hard starting diesel
My knowledge about diesel is extremely limited. 1989 Jetta, 5 speed, deisel. Starting this past summer, (prior to the summer, every thing was fine, so it's not a temperature thing) it would take 30 seconds for the motor to start after the glow plug would go out. It didn’t matter if the cold handle was out or not. Unburned diesel smoke would envelop the car and then it would finally start with an even bigger plume of smoke. If this was a gas burner, then I would look for something within the carb that was flooding the engine. I know little about fuel injectors and less about glowplugs. Though, the glowplug light comes on and then goes off after a few seconds, could it be bad? Any help would be greatly appreciated, as my daughter is getting to like my car too much.
Old 12-21-2004, 05:00 PM
boschmann boschmann is offline
Re: hard starting diesel
You should have the glow plugs checked.
Old 01-06-2005, 09:06 PM
Bluestreet Bluestreet is offline
Probably bad glow plugs, The indicator light is lit up by the glow plug relay and it doesn't mean the glow plugs are good.
Old 01-09-2005, 03:27 PM
swipter swipter is offline
Is that something you can do yourself or does it require 5 "special" tools?
Old 01-10-2005, 10:08 PM
Glow plugs shouldn't require any "special" tools. If you can remove the stuff out of the way to get to them.
