Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-18-2004, 02:19 AM
george536's Avatar
george536 george536 is offline
GST Hardtop or drop top?
ok i searched and didnt get a clear answer on the differences between the covertible gst and the spyder gst, other thant the obvious top and the trunk. do they both run the same times in the quarter mile? or is the spyder heavier? I really want a convertible but also want to know if ill get the same results when i start modding as if would get on a hard top.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 12-18-2004, 03:09 AM
Legionofone's Avatar
Legionofone Legionofone is offline
Re: GST Hardtop or drop top?
weight would definaly play a part... the times would slow but only marginaly... a few mods would get u right back up to normal i would say go for it just for the added coolness of a convertable
Old 12-18-2004, 03:12 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Well, to answer your question about the weight difference the answer is yes, the spyder is heavier. I dont know how much heavier, but you can go to autos.msn.com to see the weights. To see the stock track times, do a seach in this forum that has the title "Stock Times". I posted the thread a while back for a useful guide for people wanting to get a comparison of the stock quarter mile runs. Hope this helps.
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 12-18-2004, 08:51 PM
2of9 2of9 is offline
yeah, but in my opinion, if your going to get a hard top GS-T, mite as well go for the GSX, cuz a Spyder GS-T would be a nice ass hell ride and it would have the power to show its looks off, well, thats me tho. and yeah, the Gs-T Spyder is heavier than the hard top.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-19-2004, 09:04 PM
joemathews's Avatar
joemathews joemathews is offline
Spyders are heavier, and their tops leak like hell. Just as Vince if he enjoys having his car when it's raining....between the 300 hp fwd and the drop top, it can't be fun in the rain
1996 Eagle Talon
Old 12-19-2004, 09:39 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
ya , i live in Wisconsin and i can only imagin the problems spyder owners here have...with the snow and all...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-20-2004, 08:26 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Yea the spyders do leak a bit. I have a 99 GST Spyder , but I have noticed that with a top replacement my top doesnt leak at all anymore. I replaced my top about a month ago and I havent had a single leak yet.
But you know what does suck? We had our first snow of the year here in Jersey lastnight.(It was bearly anything) But my door froze shut and my door handle broke off in my hand about 1hr ago.
Old 12-20-2004, 10:31 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
If I remember correctly the Spyders are about 70 lbs heavier than the hardtops. After intake, DP & Hi-Flow cat, I was running about 1 car length faster than my buddies hardtop (at about 80 mph). So like legion said....It doesn't take much to catch up.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-20-2004, 01:40 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
just got a new top so no more leaks
we are a bit heavier and closer to the GSX weight. but i think that we may have a bit less wheel hop issues than hardtops. one of my bro's got it bad in his hardtop, far worse than i ever had it.
we [spyders] have the GSX chassis for added support because of the rigidity lost to not having a top. that means we can do a bolt on GSX conversion. just get the tranny back from a trashed GSX and you are in business. but you do have to get a roll cage so you will not twist into a pretzel. and if you want to run on any track in CA you have to get a roll cage.
the gears on the motor for the top are made of plastic and will strip after prolonged use.
weather stripping is usualy trashed.
back seat and trunk is smaller than you can imagine.
other than that it is the shit. take the badges off and people will ask you what kind of car it is. at least they do for me.
Old 12-20-2004, 08:53 PM
hey, has anyone ever tried like a hard top conversion, i mean like, you can take off the hard top instead of having a "convertable" top. Like...the ones the S2000s..not sure if they do, but i mean like another hard top you can take off instead of waiting your head to be covered by that plastic.
--2OF9--
#808/1000
Old 12-21-2004, 08:41 AM
What do you mean "waiting your head to be covered by that plastic"???.
1999 Eclipse Spyder GST-Race
-DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous
Old 12-22-2004, 06:11 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
I think it also all depends on where you live. If you live where it doesnt rain much i would go with the drop top, but if it rain go with the hard top. I would personaly go with the hard top since i really dont like convertibles. Dont get me wrong, i think they look bad ass, but they are not for me (I feel too vulnerable).
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 12-22-2004, 06:17 PM
george536's Avatar
I live in cali. Rain over here is not bad. So im still kind of thinking about it. theres a green 96 gsx for sale that i can get, but i want a gst. im just gonna play on the freeway and from a roll most likely if i do want to race someone. and i really want a 97-99 so im just gonna wait for one.
-1990 Eclipse GSX
Old 12-22-2004, 09:20 PM
hahaha...i mean like instead of waiting for the thing that goes over your head in your convertible...(shit, my bad if i dont make sense) i mean like, a hard top you can install without waiting for the plastic thing to cover your interior
--2OF9--
#808/1000
Old 12-22-2004, 09:43 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
a removable hard top you can't take with you
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
