Old 12-18-2004, 12:54 AM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
valve tapping
i had my valve lifters replaced a while back. ever since then i have had the annoying and most dredful valve tap. should i take it to my mechanic and have them re adjust the valves? or am i stuck with this?
Old 12-18-2004, 03:28 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: valve tapping
Is it constantly happening or only on startup?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-18-2004, 11:21 AM
Re: valve tapping
constantly. it is loud the 5 seconds after start up then gets quieter..
Old 12-18-2004, 04:45 PM
gbic1 gbic1 is offline
How often do you change your oil? What weight oil do you use? Generaly when an engine needs lifters it is due to lack of oil changes. Any debris in engine will block oil passages and cause this to happen. If this was the problem than it will take many oil changes with HD oil to clear this up.
Old 12-18-2004, 10:57 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: valve tapping
What oil filter are you using?
Old 12-19-2004, 03:52 PM
Re: valve tapping
i change my oil every 2500 miles. my lifters went on me like 6 months ago due to overheating. i wasnt driving, my retarded brother took my car for the day. i use 10W-30 with a AC Delco filter. i used to use a fram
Old 12-19-2004, 08:45 PM
BlazerLT's Avatar
AF -Advisor
Re: valve tapping
First of all, don't change your oil every 2500 miles.
HUGE waste of money and oil.
Change it at 5000miles.
Other than that, on your next change, run an engine flush treatment through it to clear up any restrictions.
Old 12-20-2004, 01:14 AM
SlammedClipse SlammedClipse is offline
Send a message via Yahoo to SlammedClipse
Re: valve tapping
and maybe try a purolator filter, stay away from fram, not sure about ac delco but purolator seems to be best...
1997 Chevy Blazer LS(Nothing Done Yet)
2001 Dodge Durango(Nothing Done Yet)
2003 Mitsubishi Eclipse GS Sporty
-Injen Cyborg Cold Air Intake
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Greddy Evo2 Exhaust
-Enkei 18" Rims
-Tanabe Lowering Springs
-Stinger Alternator
-Ripp Mods Header
Old 12-20-2004, 06:40 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: valve tapping
Try relashing it... It may be nothing more than a loose rocker. Re-lash it and see if it quiets down. If it doesn't you could have a bad valve seal that's causing the valve to stick open (until the piston taps it shut)
Old 12-20-2004, 09:49 AM
You are kidding right? Piston hitting the valve and shutting it? If the piston it the valve 99% of the time it will bend it.
Old 12-20-2004, 01:50 PM
BlazerLT's Avatar
AF -Advisor
Re: valve tapping
I think there is just some gunk in the oil system that needs to be cleaned out.
Engine flush treatment works wonders and really quietened mine on startup.
It is -31c here yerterday and not even a click from the engine compartment.
Old 12-20-2004, 06:38 PM
Mikado14 Mikado14 is offline
HOW COLD? And I thought 4f here on the farm this morning was cold.......
Old 12-20-2004, 06:40 PM
Re: valve tapping
He has to be kidding. A bad valve seal should have no effect on valve travel or causing it to stick open. However, he could be right on readjusting the lash.
Old 12-20-2004, 07:31 PM
Re: valve tapping
which engine flush treatment works best??? ill try doing this tomorrow, being that it is 2 degrees right now. not something i want to be in working on my car.
Old 12-20-2004, 07:44 PM
BlazerLT's Avatar
AF -Advisor
Re: valve tapping
oh, two degrees there, you need to switch to 5w30 for starters.
Engine flush I would use would be the one from the Gunk brand of products.
Just floow the instructions on the bottle and add it to warm oil and idle it for 30 minutes.
Also, I would swap a new filter on during the treatment so it will catch all the sludge being removed from the system.
Then drain the oil completely and and drain thoroughly and install another new oil filter and 5w30 oil.
