Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-18-2004, 12:02 AM
ls1mazda93rx7's Avatar
ls1mazda93rx7 ls1mazda93rx7 is offline
Talking think turboing your fb or ta is a pain think again
turbo your lt1 and ls1, http://www.ststurbo.com/home. watch the videos please
Old 12-18-2004, 12:27 AM
silver87ta's Avatar
silver87ta silver87ta is offline
Re: think turboing your fb or ta is a pain think again
Nice...but if it replaces the muffler, how is it still street legal? and what's it gonna sound like?
02 Formula 5.7L V8 LS1
SLP Lid, SLP MAF, SLP Cold-Air Induction, WS6 ViS Carbon Fiber hood
Gone but not forgotten: 87 Trans Am 5.7L V8
My first true addiction
Old 12-18-2004, 10:40 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Re: think turboing your fb or ta is a pain think again
2 friends of mine have this system...I'm thinking of switching over...but its quiet until you get on it and even then its not that loud. Its legal because you keep your stock manifolds and cats.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 12-18-2004, 11:17 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
Remote turbos are bad!! If your going to turbo a car, do it the proper way. You know that turbos work from the exhaust pressure? Where is the most pressure located at? Not at your muffler thats for sure. You want a turbo located as close as possible to the exhaust manifold to increase efficiency. You also have the concern of the turbo being directly exposed to the elements that gets kicked up i.e. debris, rain, snow, sand, dirt, etc. Who wants a rusted turbo? I'm not trying to be rude, but if your spending 4k on a turbo kit, do not buy a remote kit! Lag is also going to be more of an issue since it will have less pressure to build up quicker. Don't trust everything they are throwing at you, cause they are trying to sell there product like everybody else. They are simply telling you what you want to hear.
Old 12-19-2004, 07:47 AM
cndctrdj cndctrdj is offline
Send a message via AIM to cndctrdj
they have actually fixed most of the problems you talk about. no lag and still enough pressure. yes you have to still worry about debris on the road hitting it. its not a bad kit ive read a few reviews on it.
95 TA - fast
92 240 - fun
96 prelude si - lots o fun
94 cr500r - rediculously fast and fun
Old 12-20-2004, 05:04 PM
DarkblueTA's Avatar
welcome to 6 months ago arguement. So tell me great one, whats the difference in pressure from right off the manifolds vs back the tailpipe if there are no leaks between the manifolds and the turbo(no matter where its located).
Whats the difference if the turbo is out back where it is or down low in the engine bay like some of the other kits place them? there is no difference other then its not in the engine bay. Rusted turbo..is that like my rusty exhaust pipe
Lag is not an issue. I've rode in 2 STS cars. one with a T60 the other a T67. virtually NO lag. The T70 turbo on this kit was the same way.
Yeah...don't trust what you're telling us...because I've been there, seen that on the street and at the track.
DarkblueTA
Old 12-20-2004, 08:05 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: Re: think turboing your fb or ta is a pain think again
well umm, there is not that much pressure difference but, heat drives a turbine just as much as pressure. It's colder back there. Oh and yea, there is no lag at 10 PSI but, try to run a turbo that will support 23+ PSI. Lag bad time.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-20-2004, 10:37 PM
ha ha ha try to run your ls1- lt1 at 23psi, lag wont be your problem
95 TA - fast
92 240 - fun
Old 12-22-2004, 01:51 AM
Kurtdg19's Avatar
If you could explain to me how a remote system is better, than I'm all ears. Like you said, this is a 6month old argument, I would assume it should be clear.
Since when is a turbo suppost to run cooler? Its purpose is to absorb the wasted thermal energy. This site seems to believe that heat is the setups enemy???
Yours Truly,
Not the Great One
Old 01-20-2005, 06:26 PM
monkey-leader monkey-leader is offline
Send a message via MSN to monkey-leader
I AM NO COLLEGE PROF. So bear w/ me
There is no significant difference in pressure. However, there is a lot more space between the exhaust port and the turbo, so it is a different flow pattern. Which causes 2 problems (that i can see);
A) There is more lag due to the fact that the gas's have much more space to compress. If anyone here has ever had air compressors, you know that it takes longer to compress a 50 gallon tank than a 7 gallon tank. (which is about the difference).
B) The gas's (as stated by sts) are much cooler. This is great for turbo life. It does reduce the efficiency of the turbo because the gas's are more dense and will not spin the turbine as fast as the hot gas's.
As for your debris/weather concerns. It will rust anyway, and dont drive on shitty roads! :P
All in all it is a good idea. But it is mostly talk and not enough rock.
The standard method will produce more power, and isn't that all we really want?!?!
Old 01-20-2005, 07:23 PM
CreepingDeath94 CreepingDeath94 is offline
Just when you think a thread is dead...
Old 01-20-2005, 11:55 PM
Hypsi87's Avatar
closed
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Closed Thread
