Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 12-17-2004, 11:56 PM
ls1mazda93rx7's Avatar
ls1mazda93rx7 ls1mazda93rx7 is offline
Lightbulb what do you think about rear mount turbo(STS)
well its only for non turbo/supercharged cars, but if you look at the sts turbo kit, i bet you cuold make one for the rx7. well??
Old 12-18-2004, 12:00 AM
Re: what do you think about rear mount turbo(STS)
http://www.ststurbo.com/home
Old 12-18-2004, 12:20 AM
fcdriver fcdriver is offline
Well from the ways I've read about turboing a N/A FC you're better off going with a T2 lower and upper intake manifolds along with the entire wiring harness and ecu. You'll also need the front cover for the oil and cooling lines running to the turbo from a T2 engine. You can also use your N/A intake manifolds but it seems like it would be harder to since you would need to fab several custom parts.
Now with that said, from what I understand about the N/A engine you can't run to much boost for obvious reasons 1) high compression, 2) it's a 6 port instead of a 4 port.
Now this isn't to say that it can't be done but it seems it would be cheaper and more feasible to buy a turbo car or buy the turbo engine, harness, ecu and trans since the N/A trans won't hold up to well with much over 200 hp.
Old 12-18-2004, 12:37 AM
maybe it would be better for the rx8.
Old 12-21-2004, 01:23 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
rx8 = 6 port for the 6 spd.
(auto is 4 port)
RX-7 TII
Old 12-21-2004, 10:55 AM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
turbo setups work well with a 6 port, but all in all, we're better with turbo engines in our rx7 if we want to go turbo, its just cheaper and more reliable
the compression on the 8 will not allow very high boost numbers
