Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-17-2004, 11:12 PM
froggrog froggrog is offline
Smile Hazard Light Module Ticking
Do you hearing ticking just like when you turn your signal light on but only you don't have any signal lights on ? If so, the ticking is coming from the hazard light switch/module. The problem is not with this module but rather with the whole control arm assembly in the steering column. Chev decided it would be a better idea not to have individual modules to change out but instead force you to buy the whole complete assembly. I bought this assembly for $180 CDN, changed it out and the ticking stopped. You do not have to remove the steering wheel to change this component. Here is the procedure.....
- Remove the 3 screws underneath the steering column cover
- Remove the top and bottom pieces of the steering column cover
- Remove the 1 screw on top of the assembly
- Lift the assembly up and remove the 3 wire connectors
- Connect the 3 wire connector to the new assembly
- In stall the new assembly ***be careful to align the pin for the horn before completely seating the unit.
- replace covers in reverse order of removal.
Hope this helps everyone.
Old 02-07-2005, 11:16 PM
Mikado Mikado is offline
My Malibu Has All The Bugs!
Dang! I finally found a place that has answers to all the Gremlins in my Malibu! I have never seen a car with so many faults! It's those little things that drive me nuts, such as the hazard light blinking thing, the blower switch only working on numbers 3,4, & 5, the intake manifold leaking antifreeze (I am sick of smelling that crap), and most recently, the gas gauge needle below the peg! What's up with that?!?!?!? SHEESH!
Oh yes, I forgot the ignition switch! It decided to lock up on me after I bought groceries. AAA sent a locksmith out. Nice kid....said he'd have me on my way in a jiffy as soon as he broke the lock! TWO HOURS LATER he drills the dang thing out and I go around for several weeks starting it with a screwdriver! The replacement was simple, but $75 here.....$50 there.....I think Chevrolet should be ASShamed for producing such junk.
One more thing....it thinks brake pads are chewing gum! However, I got to admit, when you step on the pedal, it will move on down the road. It has 150k miles and doesn't use a drop of oil!
Thanks guys for all the info!
