Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 12-17-2004, 05:48 PM
jbmann jbmann is offline
help my electrical problem
my expeditions airbag light is on, the horn quit working, cruise control quit! What the hell is up with it. Can anyone help. Is it a relay and if so which one. All fuses are ok.? Please help
Old 12-26-2004, 05:38 PM
draasch draasch is offline
Send a message via AIM to draasch Send a message via Yahoo to draasch
Re: help my electrical problem
check the fuse box under the hood too.....
Old 12-26-2004, 07:56 PM
ncinirator's Avatar
ncinirator ncinirator is offline
Send a message via AIM to ncinirator
Sounds like a tuarus problem.
94 Caprice 9C1, 84 CUCV Blazer, 07 TL, 96 F250 PSD.
Old 01-08-2005, 12:01 AM
al52269 al52269 is offline
Hello!
Hope your well...
I had the same problem on my 1993 Ford Aerostar.
It's call a (Combination switch) or (Clock something can't remember) It was done years ago. This module controls the airbag / horn/ cruise control/ exc.
It's located inside the steering wheel behind the airbag.
You or the Mechanic have to take the air bag out (note: Be very careful when removing the airbag due to it may deployed and cause injuries.) Also it will cost a few hundred dollars to replace the airbag. That's why I had my Mechanic do mines it cost me $150.00 parts & labor. Hope this helps. Good Luck. Sincerely, Al
Old 01-11-2011, 10:32 AM
zergyo zergyo is offline
It's called the "clockspring" and it's pretty common......
