Old 12-17-2004, 02:31 PM
nicemunkie nicemunkie is offline
my truck's not level
I've got a 97 k1500 that is a full inch lower on the left side than it is on the right. All the suspension is stock. I've thought something looked weird for a while now and finally got around to measuring it. I'm not too rough on the truck, though we have had our days (and nights) in the mud. Do you think something is bent? Seems kinda weird to me. It's lower all the way, front to back.
Old 12-17-2004, 02:37 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: my truck's not level
Just to clear things up, is it on the passenger or driver side? a possibilty would be that the factory rubber body spacers are worn, or gone.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 12-18-2004, 12:08 PM
No it's lower on the driver's side.
Old 12-18-2004, 12:15 PM
Sorry, I wasn't done responding when I hit submit. Any way it is on the driver's side. I'll go get under it this afternoon and see if I can see these spacers, but I'm not sure where to look.
Old 12-18-2004, 12:21 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
I think my 92 is the same side, in the rear though not the front. In the back it's gotta be in the suspension because if you look at the wheels one sticks above the top of the frame and the other wheel is a little below the top of the frame yet nothing on the suspension is broken at all, shackles and hangers are just fine.
Edit: tonight after i'm done hunting i'll pull her in the garage and take a few more measurments and see what i can help you(and myself) out with.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 12-18-2004, 03:45 PM
J-Ri's Avatar
J-Ri J-Ri is offline
When you say the left side is lower, is this measuring to the frame or the fender? If it's to the frame, suspension/tires are your problem. Check the tires for the correct PSI. You need to flush the summer air out and refill with winter air anyway
If you're measuring to the fenders, check those spacers Silverado Brethern mentioned.
Old 12-20-2004, 08:36 AM
HardcoreZ28 HardcoreZ28 is offline
Crank up the torsion bar on that side. I had the same problem with my truck. About 3 turns should give you an inch or so.
Old 01-04-2005, 06:07 PM
DAllen&Son DAllen&Son is offline
Send a message via AIM to DAllen&Son
have you checked to see if the ground you are on is level, no offense but this can through of the eyes.
Old 01-06-2005, 12:37 PM
planedude planedude is offline
Is the truck full of fuel when you measured it? As the fuel tank is on that side..
Old 01-06-2005, 06:22 PM
v10_viper's Avatar
Re: Re: my truck's not level
Ya know I never thought of that and it seems fairly logical. If it's full of fuel then that's around 220 lbs (28 gallons) and that could make a slight difference, maybe I'll have a friend stand on that side sometime as my gas tank never goes over half full anymore. Being a half ton I think it's a good thought.
