Old 12-17-2004, 01:16 PM
anthony90si anthony90si is offline
pr4 or pm6
hi i was just wondering if with a b18 if it would make a difference with the 2 different ecus. at first i had the teg ecu in but now i put in the old si ecu since it bolts right up. i just want to know if i can still get the same performance. and once get my turbo will i still be able to stick with an si ecu with out making performance suffer alot.
thanks
Old 12-18-2004, 03:49 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: pr4 or pm6
you can use either ecu and it will run safely. As for the PR4, it will run your motor slightly better as it has fuel maps for the 1.8.
I don't suggest running either ecu with a turbo. You're gonna be running extremely and dangerously lean if you turbo and retain your stock tuning. You could use either and just use an safc or chip it.
But overall, I would recommend the PR4.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-18-2004, 05:15 PM
Re: pr4 or pm6
thanks man
Old 12-18-2004, 08:58 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
pm6 would make it run lean, pr4 runs ideal. since the pr4 is made for the b18. u can get an adjustable fuel pressure regulator, larger injectors and get ur ECU chipped with proper maps if u go turbo. would prolly be the best way and run an air/fuel gauge too
Old 12-19-2004, 04:21 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: pr4 or pm6
PR4 pulls harder, Ive had both.
When I first bought the car it came with a PM6 went to the junkyard got a PR4 and it pulls and performs much better.
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-20-2004, 03:27 AM
Re: pr4 or pm6
thats weird cause i don't really see a difference
Old 12-20-2004, 08:16 AM
Re: pr4 or pm6
I didnt at first either.
I felt the difference up top, down low seemed to be pretty even until a certain point.
1991 Honda Crx Si
