Old 12-17-2004, 12:20 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Talking 1/4 and 0-60
I just got back from running my truck at the track. My time in the quarter was 16.79 and 0-60 was 9.02. is that good or what? i have nothing more done to the truck than what is in my signature and i figure it weighs around 6500lbs. anyone else have some #'s for thier stock-erado's?
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 12-17-2004, 07:01 PM
Thunderbolt Thunderbolt is offline
Re: 1/4 and 0-60
I don't know if it is a good time or not, But I do know your truck doesn't weigh anywhere near 6,500 pounds unless you had over 1,000 lbs in the bed. I have the same truck and on an official scale it weighed just under 5,300 lbs. The times sound right from things I have read about them.
Old 12-18-2004, 03:55 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1/4 and 0-60
If you look at his signature, he's got the HD chassis package. That adds a lot of weight. His exhaust is also most likely bigger than stock, making it heavier. It's also 4x4 and that adds a lot of weight. I have an 86 HD, and it weighs at least 6,500 pounds (welded-up reciever hitch, heavier springs, 1-ton rear axle). Mine does have metal where the new ones have plastic, but I don't think they save too much weight with plastic. I'll take mine to a quarry or a weigh-station in the next few weeks and see what it actually weighs.
And that is a pretty good time for a full-size truck, Similar to what mine does, but I just counted the seconds from a stop on a level stretch of highway.
Old 12-18-2004, 06:20 PM
Re: 1/4 and 0-60
Yeah i do have a 1-ton axle and 3/4 ton leaf springs in the rear but 6500 is just a guess. Next time i get a load of stone i'll get a receipt. however...last nite i went down to a local stretch of highway where we often try to find cars to race and i got beat by a 4.3L s-10. and i dont think he has anything done to it other than exhuast. i had 106 octane if it makes a difference or not but im guessing his truck weighs at least a ton less than mine and he has a 5-speed.
HD chassis package
Old 12-19-2004, 12:30 PM
Re: Re: 1/4 and 0-60
I did read his signature and seen he has a heavy duty chassis and like I said I have the same truck. The 1/2 ton Chevys with the HD chassis package consited of an extra leaf and the 14 bolt semi floating diff with 6 lug wheels and bigger rear brakes. It is the same diff they used in the 7,200 Gvw 3/4 ton. Chevy has never made a 1/2 ton truck that weighs 6,500 lbs. The new Hd 3/4 tons barely weigh that. His signature also did not say he had a 1 ton diff, But that would still not even put it close to 6,000 lbs. If I had to guess I would say it weighs somewhere around 5,600 - 5,800 depending on what extras are on the truck.
Siverado Brethern , Let me know what it weighs when you put it on a scale because I am curious. You should be able to beat an S-10 on the highway at least, But I am not sure from a stop. I just smoke one the other day and even slowed down to let him catch up and took off again all the way to the speed limiter at 100 mph.
Old 12-19-2004, 07:21 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Re: 1/4 and 0-60
I would think that it being a Vortec 350, it would run a little better. The ones I've seen are as fast as the new body style trucks, especially out of the whole.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 12-19-2004, 07:24 PM
Re: 1/4 and 0-60
All 4WD 1/2-ton Chevrolets since 1988 have 6-lugs wheels.
**1966 Chevy II**
Old 12-20-2004, 08:58 AM
I probably should have been more clear on what I was trying to say. I didn't mean that the trucks without the HD chassis package didn't have 6 lugs. The 14 bolt 9.5" semi floating rear differential in the HD 1/2 ton comes in a couple different configurations and one of them uses 8 lugs. The C/K style Hd 1/2 and light duty 3/4 ton use the 6 lug version and the heavy duty 3/4 ton uses it with 8 lugs as the standard diff and the 14 bolt 10.5" full floater is an option. On the new body style the old 1500Hd used the semi floater with 8 lugs as did the standard 3/4 ton without the optional 10.5 " full floater. Today the 1500 silverados are no longer available with the 14 bolt semi floater or so I am told by Chevrolet and I have never seen one.The standard 2500 comes with the 14 bolt semi with 8 lugs and the 2500 HD uses the full floater.I should have been clearer because it sounded like I was saying that they didn't normally come with 6 lugs.
Old 12-20-2004, 09:31 AM
AKWE-gt AKWE-gt is offline
why were you running a 106 octane?
[size=5]
Old 12-20-2004, 05:18 PM
Re: 1/4 and 0-60
a lil added pep cant hurt
HD chassis package
Old 12-22-2004, 01:05 PM
you shouldn't find any xtra pep in racing fuel on a stock engine.
[size=5]
Old 12-22-2004, 11:17 PM
Re: Re: Re: 1/4 and 0-60
Well, you know your stuff, lol.
I didnt want to sound like a butt hole, but being that I have a 92 K1500 4WD, I just wanted to clear up that 6-lugs on 4WD Chevrolets (and GMCs) are the norm, lol.
I actually didn't realize that some 3/4-ton C/K series trucks only had 6-lugs, lol. A guy that we race with pulls his car with a C2500 (somewhere in the 96-98 range with a small block) with only 6-lugs. I was thinking he must have gotten ripped off or that maybe 2WD 3/4-ton trucks only had 6-lugs during those models, but now I know he must have the light duty version.
**1966 Chevy II**
Old 12-23-2004, 07:21 PM
Ground Rat's Avatar
Ground Rat Ground Rat is offline
Send a message via AIM to Ground Rat
Re: 1/4 and 0-60
I believe mine was supposed to be a mid 15 stock. I've never ran it at the track though.
'87 Turbo Sprint
'90 Turbo Voyager
'92 Typhoon #591
Old 12-25-2004, 08:30 AM
Bill Miller Bill Miller is offline
Re: 1/4 and 0-60
S.B.
The only thing that 106 octane fuel is going to do for you is kill your cat. You won't see any performance gains w/ a stock motor. It will give your tailpipe that nice ash-gray color though.
Old 12-25-2004, 08:12 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Maybe he likes it that color . And likes blowing a ton of money to make it that color.
