Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-17-2004, 11:54 AM
jscottk70 jscottk70 is offline
Send a message via ICQ to jscottk70
96 Suburban leaking oil at oil filter
I have a 96 Suburban 2500 7.4 4x4 and it is leaking oil around the oil filter housing. There are two square headed bolts that bolt oil filter housing to the engine. Has anyone ran across this leak before? I thought a 3/8 inch drive head would fit the bolts but it does not. Does anyone know what the size is? Is there a gaset under there? Any input would be greatly appreciated.
Scott
Old 12-17-2004, 12:42 PM
ffmike's Avatar
ffmike ffmike is offline
oil leak
There is a gasket for the oil filter mount, that is probably all that is wrong. I dont know what size the bolts are though.
Old 12-22-2004, 06:37 AM
mrrpm mrrpm is offline
Re: 96 Suburban leaking oil at oil filter
Bolt will be metric, probably 10mm
Old 12-28-2004, 01:08 PM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
A lot of times when the filter gets too hot the gasket melts and sticks to the block. Just take a gasket scraper or some light sand paper and smooth it out. Then torque the new filter down good.
Old 12-28-2004, 01:12 PM
decoy86 decoy86 is offline
Make sure it is not the rear of the Intake Manifold leaking. With the orange type antifreeze it may look like engie oil. This is very common and will need a intake manifold reseal..
