Old 12-17-2004, 11:27 AM
Jenn07 Jenn07 is offline
????95camaro HELP!!!
I have a problem with my car .... well a few of them actually
1. my temp gauge goes crazy. Sometimes i cant even get four blocks with out it hitting 260.. but it should not even be warmed up yet?? if i turn on the heater to cool it down it blows Ice cold air.. when it starts to blow warm air the temp will drop... it dose this almost every time i drive it.. right now it is cold outside so i dont think its really overheating.. idont know it is weird..... please help if you have any ideas.. (i have already replaced my thermostat
2. my second problem is when i drve at like 45 50 or 55 it jumps .. almost like it is missing but i dont think it is..
*** any help would be greatly appreicated**** thanks
Old 12-17-2004, 12:38 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: ????95camaro HELP!!!
your car jumps or your speedo cluster jumps?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 12-17-2004, 12:44 PM
you can feel it jump or sputter i dont really know how to describe it but you can also see it on the rpm gauge and the speedometer
Old 12-17-2004, 12:49 PM
for your temp problem i would first replace the thermostat and for your 2nd problem i would have the car scaned for codes (at either a dealership or autozone, autozone does it for free) after you get the codes it will more than likely will tell you what could be causing your sputtering
Old 12-17-2004, 12:55 PM
I took my car to an auto zone already and it wouldnt read any codes off of my car, he said that there is some electrical chip in cars like mine that block the scanner from picking up any codes.. I guess ill have to take it to a dealer...
I already replaced my thermostat.. unless there is more than one... is there? Im not very car savy!
Old 12-17-2004, 12:56 PM
also when your temp gauge says 260 does the car smell hot? if you were to open the hood would it be a lot more hot than usual? btw does your car have a v8 or v6?
Old 12-17-2004, 12:57 PM
For the jumping or the sputtering might it be the fuel injectors or mabe even the fuel filter?
Old 12-17-2004, 01:00 PM
oh wait you have a 95.... thats right.... i used to have the same problem when scanning codes.... you need a special adapter for just that year....and no their is only one thermostat.....but make sure that you bled the lines of any air that possibly got into the lines when installing the thermostat...
v-6 no sometimes i dont think it is hot... the temp changes so fast that i dont think it is possible.. like with in 10 seconds it can go from185 to260 and back down again
Old 12-17-2004, 01:02 PM
how would i have bled the lines ?? i dont know if i did cause im not familiar with all the terms..
Old 12-17-2004, 01:04 PM
sounds like a sensor malfunctioning or an electical problem... im not the guy to talk about as far as that.... atleast that should cost you less than if your car was actualy overheating...
Old 12-17-2004, 01:10 PM
i'm not totaly sure on a v6, but on an LT1 V8 their are 2 bleeders http://shbox.com/1/bleeders.jpg that will show you what to look for -Idle the engine and monitor the temp. If the temp goes abnormally high, you may have an air pocket. Open the bleeder screws after the thermostat is open to remove any air. Only a stream of coolant will come out when all air is gone and there will be no spitting or hissing.
Close screws and monitor the temp.
this link will give you more information about your cooling system and sensors involved http://shbox.com/1/4th_gen_tech2.html#cooling
Old 12-17-2004, 01:14 PM
yeah.. i hope so.. thanks for all of your help any ways....... but about bleeding the lines? how is that done
Old 12-17-2004, 01:15 PM
thanks for your help!
Old 12-22-2004, 04:15 PM
NINÅ's Avatar
NINÅ NINÅ is offline
Originally Posted by Jenn07
1. my temp gauge goes crazy. Sometimes i cant even get four blocks with out it hitting 260...............
No you're not overheating. You have a loose connection in the temperature gage circuit. This is a technically easy problem. However if the bad connection/part is behind the dash it's time consuming to repair. So lets start the easy half. Make sure you have a good connection under the hood at the temperature sensor. It is located on the left side of the engine block.
REFUSE
. TO . LOSE
