Old 12-17-2004, 11:05 AM
dwaynlakrz dwaynlakrz is offline
Angry i need help
I Have A 1999 Intrigue ----and The Horn Keep Burning Up!!! What Seems To Be The Problem!!!!i Have Bought 2 Horns In The Last Week. I Put It On In The Morning To Check To See Do It Work,blow It A Couples Of Times--every Thing Fine --wake Up In The Morning It Don't Work.(fried)
Old 12-17-2004, 12:53 PM
paulkramer paulkramer is offline
Man these cars are pains in the .......rear!!! Like the Lucas Princes of Darkness of years past!! I hope those poor suckers who lay out those huge amounts of cash for Cadillacs are getting better electrical systems than we are!
Old 12-21-2004, 07:26 PM
panzer dragoon panzer dragoon is offline
Re: i need help
something like a horn is so simple electrically that it doesn't make any sense for one to blow unless the unit is faulty to begin with or there is some sort of short. Find a comparable voltage horn at an autosupply shop or junkyard. Is water getting into the horn to short it out? Ocean salt corrosion issues causing a short?
I don't have a service manual yet so I'm assuming that it's a 12V horn hooked right to the fuse panel and nothing else. The voltage should be listed on it (most likely 12V or alittle higher).
For electrical issues having a electrical schematic really helps so you can see what else is on the circuit.
Old 12-21-2004, 08:54 PM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
Chilton's now makes a service manual
I got mine at NAPA, but I had to wait a week or so for them to get it.
Old 12-22-2004, 08:37 AM
87accordlxi 87accordlxi is offline
Send a message via ICQ to 87accordlxi Send a message via AIM to 87accordlxi Send a message via Yahoo to 87accordlxi
Re: i need help
It sounds like you definitely have a short. Try going to a library and see if they have the service manual for your car. Many libraries stock that kind of stuff. You'll need the electrical schematic.
- Joe
'99 Olds Intrigue GX - 3.8L - Black
Old 12-22-2004, 10:38 AM
Thumbs up Thanks For The Info Everyone!!!!
I Will Be Working On This Starting Monday!
Old 12-22-2004, 06:11 PM
Rifster Rifster is offline
Re: i need help
In a '98 Intrigue, the heater in the climate control works fine but only for about two hours ... then it stops blowing heat. The problem is momentarily corrected when the engine is turned off and then back on. But the problem happens again. The water pump was recently replaced. What's the fix?
Old 12-22-2004, 08:25 PM
Question Re: Re: i need help
(DURING THOSE 2 HOURS IS THE BLOWER EVEN BLOWING OR BLOWING COLD AIR----OPEN THE GLOVE DEPT---AND REMOVE INSIDE LINER TO IT---AND CHECK THE BLOWER---WHEN YOUR HEAT GOES OUT---THIS WHAT I WILL CHECK FIRST!!!)
Old 12-22-2004, 08:59 PM
Re: Re: Re: i need help
During those two hours, the heater and blower works fine. I may have mislead you when I suggested the momentary fix was short lived. Once the engine is turned off and back on, the heater works until I get to my destination and shut the engine off. I do think that the blower is still working when the heater quits ... I'll do as you said and try to pay more attention to what is working when it stops.
Old 12-22-2004, 09:08 PM
check your vaccum and lines!!!!make sure your heater doors are opening!!!
