Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-17-2004, 07:55 AM
2000dga 2000dga is offline
Question gears slip when turning left, 2000 JGC, help!
When making a left turn, the vehicle does fine until you get at the arc of the turn, then when you start to turn the wheel back the gears slip for 4-5 seconds, then pop back into gear. Have taken it to several places and they claim they cannot find the problem.
Please help, I fear that if this is not corrected it may cause worse damage.
It only happens with a LEFT turn.
Old 12-17-2004, 08:04 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: gears slip when turning left, 2000 JGC, help!
I do not understand what you mean by the gears slip, the steering gear box? or transmission?
Old 12-17-2004, 02:53 PM
Re: Re: gears slip when turning left, 2000 JGC, help!
For instance, when I stop at a stoplight, then turn left, during the turn the jeep slips out of gear and revs up to around 2500rpm or so, then goes back into gear. If you look at the gearshift it stays in drive. I keep the jeep in 2 wheel drive.
It only does this with a left turn. And EVERY left turn.
Old 12-17-2004, 02:57 PM
well thats wierd never heard of that, have you checked the fluid level in the tranny?
Old 12-17-2004, 03:00 PM
JDPascal JDPascal is offline
Check your transmission fluid level.
Vehicle should be at operating temperature, on level ground, engine running, transmission in neutral and park brake on.
Make sure that the fluid level is at the full mark with the transmission hot, not over full and not below. Also check the smell and color of the fluid. Should be red in color and not smell burnt. compare the smell and color to some new ATF right out of the bottle.
JD
Old 12-17-2004, 03:07 PM
JD
I had checked it before with the engine warm, but not running. I will try as you say and get back to you. If it is low, must you use the exact type of fluid in the manual? Or are all pretty much the same?
Old 12-17-2004, 03:13 PM
make sure to use the exact, u can use aftermarket brands ATF+4, but I recommend using the MOPAR ATF+4
Old 12-17-2004, 03:36 PM
The owners manual for the 95 will probably call for Mopar ATF+ . The newer Mopar spec is for ATF+3. I would just use it. The ATF+4 is way more expensive and adding the little to bring it up to full probably won't give much benefit.
If the transmission fluid is being changed, then ATF+4 would be good and a synthetic like the amsoil product or Mobil 1 ATF would be even better.
JD
EDIT-- several Mopar transmissions REQUIRE the ATF+3 or +4 and it is claimed that if Dextron or Mercon ATF is used, it can cause slip and shift problems. Some of the experiences posted on this board seem to support this claim.
JD
Old 12-17-2004, 06:16 PM
I was under the impression that all the WJ models were required to use ATF+4.
Old 12-17-2004, 07:38 PM
oops!!!!!!!!!!!!!!!
Sorry didn't remember the thread heading -- Some how I was thinking "95" -- my BAD!!!!
Thanks for the wakeup dk
JD
Old 12-18-2004, 03:24 PM
no problem, thats why I'm hear...lol
Old 12-18-2004, 06:41 PM
I checked with everything just as you said, and the level was barely up to the first hole in the stick! How could it have been that low? It's parked on a cement garage and no leaks are noted. Anyway, I got the Mopar +4 and we put enough for it to be between the "hot" holes. Am I correct? I test drove it and of course no slips! But I am concerned where the fluid loss is coming from.
Old 12-18-2004, 08:44 PM
msrjeep msrjeep is offline
Send a message via AIM to msrjeep
mopar ATF+4 is the only transmission fluid you should use on a WJ. it is the preferred top off for the 99-01 WJ(which come with ATF+3) there are no "aftermarket" ATF+3/4 fluids that are anywhere near the spec of the spec of chrysler fluid. they are just dexron with some cheap additives. ZJ's use ATF+3. i still have no idea why people insist on using aftermarket fluids that are sometimes just as much as the OEM fluid (mobil/amsoil)
Old 12-18-2004, 09:27 PM
I knew the ATF+4 applications - I just had a brainf@rt and forgot the year and model in the thread heading.
I know that there are no ATF+4 equivalents in aftermarket products. That said, I see ATF+3 products from Quakerstate and others on the shelves at hardware stores and Walmart all the time....They must have to meet some (minimum) spec to label it as such. Knowing auto manufactures, thats probably all Chrysler meets too.
I was looking at the Mobil 1 ATF today and nothing was written on the label about Chrysler compatability. I did see that the Amsoil ATF on the next shelf claimed complete Chryser compatibility as well as for dextron and mercon replacement.
The Mobil 1 ATF was $7.99 per liter and the Amsoil ATF was $11.99 a liter.
I've only used the ATF+3 at about $5/liter from NAPA so I'm not sure what the cost of the MOPAR +3 or +4 is from Chrysler..- I probably should have used the +4 when I serviced the trany last time.
anyone bought some ATF+4 recently??? How much????
JD
Old 12-18-2004, 11:30 PM
the only fluid that actually meets ATF+3/4 is the oem chrysler fluid... it's proprietary. it's not just a standard or benchmark... the crysler fluid is the way it is to work with all the seals in the tranny and provide the correct amount of friction for the torque converter etc.
