Old 12-17-2004, 05:23 AM
erubin erubin is offline
pilot bearing
I just bought a clutch set and refaced the flywheel. The clutch set came with two pilot bearings. They are the same ID but different OD.
The truck is apart at my friends house. this is the firsat clutch job I'ver evr done so I need help.
Both pilot bearings are smaller OD than the hole in the center of the flywheel. I assume that's OK and that the pilot bearing doesn't actually touch the flywheel.
When i inspected the back of the engine once the trans was out i recal that there was a sort of stepped shaped piece in the crankshaft. i thought that was the pilot bearing. But one side of it was broken. the pilot bearings i have in the kit don't look like the broken piece. I need to get over there with the parts to see what's wrong.
can anyone shed some light on this?
I borrowed a pilot bearing puller from Autozone but it is too large to fit in the ID of the pilot bearings in the kit. I guess i'll have trouble extracting the old one.
Old 12-17-2004, 06:59 AM
busa_4 busa_4 is offline
Re: pilot bearing
the pilot bearing is a pressed or tight fit into the flywheel. if it is too small then it defeats the purpose of it. it needs to support the input shaft. if it is too loose the the input shaft will be moving around causing damage to the clutch system and the tranny.
Old 12-17-2004, 11:29 AM
Oh! that is a problem. I was hoping it only got press fitted into the rear of the crankshaft and not the flywheel. The truck is an hour away so i'd hate to get there with the wrong parts.
Old 12-17-2004, 11:31 AM
group4573 group4573 is offline
Banned
Re: pilot bearing
A Love Gift For You
LINK REMOVED<< Click Link
Old 12-17-2004, 11:47 AM
Busa,
before I go back to the parts store and raise a fuss looking for another pilot bearing...Is it not possible that the pilot bearing is pressed into the crank and not the flywheel?
Old 12-17-2004, 12:30 PM
Re: pilot bearing
oh, damn! sorry, i ment to say crankshaft not flywheel. you need a really small puller to get in there. the best way to remove them is to use a small slide hammer.
Re: pilot bearing
sorry, didnt mean to confuse you!
Old 12-17-2004, 03:00 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: pilot bearing
Bro, buy a repair manual for your truck, it will help you with things like this.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-17-2004, 05:37 PM
tom3 tom3 is offline
Re: pilot bearing
I usually take a hacksaw blade by itself, cut a groove through the old bushing (tedious work) and it can be pulled out of the back of the crank. Very important to replace this too as those T5 trannys will start getting real noisy in first and reverse due to bearing wear, if the input shaft is allowed to wobble around. This bushing does go in the back of the crankshaft, pretty deep in there.
Old 12-18-2004, 08:25 PM
gaggrouper gaggrouper is offline
Hey, I feel your pain.
I put a clutch in my S-10 4X4 (4.3 TBI, new venture 5 speed)a few months ago and had a similar problem. The kit I purchased had one pilot bearing (aka: bushing, some actually have small bearings) it was made of a very soft metal that looked like it was pressed together from powder during manufacturing (like an aspirin), more on that later. The bearing was the wrong size (ID) the trans shaft would not fit in it. Only, I did not test fit it on the shaft first. After removing the old bearing, I gently hammered the new one into the back of the crank, bolted the clutch assembly in place, put a new throw-out bearing on and tried to put the trans back in place. No dice. After 4 hours of trying, I dropped the trans out again to see what was wrong. Thats when I relized the bearing was the wrong size. My point of telling you all this, is because I had to get the wrong size-new bearing out. Not easy. I also borrowed a puller from autozone and it was to big for the ID of the bearing. So I modified it. I took off a little material from the ends of the tool so it would fit in the bearing. I used the slide hammer a couple of times, and the tool pulled out of the bearing, cutting two shallow grooves in the bearing. I did this several times, and each time removing some material. It was working but it was a slow process. So I used a chisel to cut the bearing away. As I said earlier, the material is very soft and the chisel went through it with little effort. I do think the saw blade idea that I read about in an earlier posting is better because you dont have to hammer on the crank (must be careful not to damage the crank). I went back to the auto store to get the correct bearing (take old bearing to compare). Once I had the correct bearing things were fairly straight forward.
The bearing should be a tight fit. It should have to be lightly hammered into the back of the crank. Be gentle, the crank has runout tolerances that can be affected if hit to hard. Also, the factory service manual that I have says to lube the inside of the bearing and to use graphite on the shaft were the throw-out bearing slides. I highly recommend you getting a manual of some type. There are numerous things to consider when doing this job, there not difficult if you know about them. One other thing that was not in the manual but makes the job easier: the manual says to remove the gear shift handle but this leaves a short lenght of shifter sticking out of the top of the trans. This made removing an reinstalling the trans very difficult. If you have not already done so, you can remove the entire shifter by unbolting the shifter base from the top of the trans giving much needed clearance.
I know this was wordy but thought it was needed to be as clear as possible. Hopefully you can get this in time to be useful.
Old 12-19-2004, 12:26 AM
Thanks for the info. I will definetely check the pilot dia compared to the trans before installing the pilot in the crank. If the pilot is that soft i bet they break all the time on install and you don't even know it. In fact the old one is broken and maybe i did that when i removed the trans.
I already took the whole shifter off since i don't have much cleareance working under jack stands. i did not disconnect the exhaust though and wiggled the trans out w/ no help and no trans jack. Maybe you recommend that i take the exhaust off now since i may break the pilot wiggling the trans back in.
The rear main seal looks good and dry. Should they be changed everytime on principal anyway?
As for manuals i have Alldata instructions (see attached image). Very limited info but with your help I hope it will go fine.
Old 12-19-2004, 07:01 PM
The bearing can take a little abuse but be easy. I would still recommend a service manual for the additional info it provides, there not that much and you may need it for something else.
If you have adequate room, leave the exhaust alone. I removed mine and broke two flange bolts, but I needed the room. You do what's needed to get the clearance.
I used a trans jack adapter attached to a floor jack and still had a time getting the trans back into position. I can't image doing it without something to firmly support the weight of the trans. You mentioned jack stands. I also used jack stands to lift the entire truck up. A few weeks later a mechanic friend of mine did a clutch on an Explorer in his driveway. All he did was lift the back of the vehicle with a floor jack on the differential. I thought it was pretty slick.
With respect to the rear main, I'm not sure. I did not replace mine, it was not leaking. And to tell you the truth, I didn't think about it, besides I had enough work to do.
Old 12-20-2004, 12:07 AM
Well everything was going great. I ground down the pilot removing tool tabs and it fit perfectly into the old pilot. With a slide hammer the old one popped out. Installed a new one. Then I assembled the flywheel and clutch parts with the alignment tool and that went great. i then mounted the new fork and throwout bearing to the trans and it all looked great. then i spent an hour wrestling with the trans getting it back in and that worked.
Here is the bad news:
The fork and the throwout bushing still don't make contact with the pressure plate. This is the same problem as we had before dissasembling. I looked in the inspection hole and can see that the throwout bushing only starts to make contact when the fork is pushed completely foreward to the end of its travel. It doesn't even start to depress the pressure plate. Very depressing.
My friend had the clutch replaced last by a mechenic that obviously had the same problem and the truck didn't work then either. I thought by buying all new parts and assembling it correctly i would solve the problem.
one theory: for some crazy reason the throwout bushing that i got in my kit from Autozone is too short (it's under 1 1/4" in length). It looks a lot shorter than the one in the diagram (attached photo in my last post). But why would the old throwout bushing I replaced be too short as well? It's as though some spacer or something is missing. A spacer or longer throwout bushing, at least an inch, maybe two inches is needed to bridge the gap. What's going on? I'm desperate. A shop manual is not going to solve this problem. Could this be a clue: the 1992 4cyl S10 pickup came with two different manual 5 spds, a Muncie or a Borg Warner T5. This truck has a Borg Warner. When you buy a clutch the trans model never comes up though. It's as though both trans' take the same clutch.
Old 12-20-2004, 12:37 AM
I checked a second source for the throwout bearing. Here is the one offered on Napa's website:
It looks identical to the one from autozone. I think it's safe to assume that I have the correct one from Autozone.
The bearing's wider diameter (bottom in the photo) should press against the spring diaphram of the pressure plate. the smaller dia side is held by the clutch fork's retainer clip.
I either need a longer bearing or some spacer placed somewhere to bridge the 1-2" gap that exists between the bearing and the pressure plate. Any suggestions?
BTW, there is no way the flywheel was ground down the 1-2" that I'm missing. i doubt the flywheel is even more that an inch thick to start with. I'm starting to suspect that the trans is not original but it bolts to the engine OK. maybe the clutch housing is too deep and needs a longer throwout bearing. How do i go about finding a longer throwout bearing? Should the bearing make contact with the pressure plate in the completely engaged position (clutch pedal released) or should there be a small gap (how small?) before stepping on the clutch?
Old 12-20-2004, 01:28 AM
OverBoardProject OverBoardProject is offline
Banned
Re: pilot bearing
I'd be more inclined to balame the fork. It's possible that it was broken, then replaced with the wrong one.
I've only heard good things about AutoZone, which we don't have where I live. If you ask them to bring in a new fork to compair they probably would.
The other possibility is the bell housing might have been changed before.
