Old 12-17-2004, 01:23 AM
pusher_sr pusher_sr is offline
gas gauge needle stuck??
i have a 97 blazer LT and just recently had my gas gauge needle stick on full after driving 200 km (about half a tank). it barely moved off the full mark. has anyone had this problem before? any suggestions? thanks for the advice. ted
Old 12-17-2004, 03:30 AM
SlammedClipse SlammedClipse is offline
Send a message via Yahoo to SlammedClipse
Re: gas gauge needle stuck??
Actually, i have a 97 LS and am currently having the same problem, but mine doesn't stick. the other day it said i was almost empty, went to the gas station and it took $4 to fill it. it's doing the same thing now but reading 1/2 tank when i know it's full. Anybody else???
Old 12-17-2004, 06:34 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Another of the known items that plague '97 Blazers which GM won't fix.(do a search on this site, you'll find many posts on this subject).
The sending unit is faulty on the fuel pump.
For this particular model, the sending unit and the fuel pump are one unit,you can't get just the sending unit. It'll run about $300 or more for a pump from the local auto parts store, $380 from a Chevy dealer.
The pump is inside the fuel tank, so figure a good 3 hours of labor to have it replaced.
My personal opinion, don't use a bone yard pump and/or tank. You'll be taking a chance at having the same problem.
Old 12-17-2004, 10:25 AM
Thanx for the info...
1997 Chevy Blazer LS(Nothing Done Yet)
2001 Dodge Durango(Nothing Done Yet)
2003 Mitsubishi Eclipse GS Sporty
-Injen Cyborg Cold Air Intake
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Greddy Evo2 Exhaust
-Enkei 18" Rims
-Tanabe Lowering Springs
-Stinger Alternator
-Ripp Mods Header
Old 12-17-2004, 02:41 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Fuel Sending unit is faulty.
Or Ignition switch in the steering column is bad.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-17-2004, 05:01 PM
what are the odds, i know replacing the pump is pricey, what about the ignition switch? should i just replace it and see what happens?
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Enkei 18" Rims
-Stinger Alternator
-Ripp Mods Header
Old 12-17-2004, 05:22 PM
tom3 tom3 is offline
Very likely a sending unit in the tank. There is a TSB on this with a replacement kit for the sending unit only, but the kit is about $100. If your Blazer has higher mileage, say 80K, it wouldn't hurt to replace the whole unit as those pumps aren't too reliable either.
Old 12-17-2004, 05:33 PM
140,000 miles
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Enkei 18" Rims
-Stinger Alternator
-Ripp Mods Header
Old 12-17-2004, 07:42 PM
BlazerLT's Avatar
AF -Advisor
You would have to probe the sending unit to see if it is getting the proper voltage.
Its' ground could be not making a good contact either.
Old 12-18-2004, 12:49 AM
would i have to pull out the tank to get to the sending unit/pump???
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Enkei 18" Rims
-Stinger Alternator
-Ripp Mods Header
Old 12-18-2004, 10:54 AM
Re: Re: gas gauge needle stuck??
Do you have a part number for this, and/or a link to the TSB?
GM and Auto Zone,Napa,Checkers, etc. only carry the fuel pump-sending unit as an integral assembly.
The sending unit alone isn't available at any of these places.
Thanks,
Mike
Old 12-18-2004, 11:58 AM
Re: Re: Re: gas gauge needle stuck??
Thanks,
Mike
I'll see if I can find that part number, been a while but I should still have it, check back later tonight or so.
Old 12-19-2004, 05:44 PM
This is from GM TSB # 83-83-07 back in March 98. For the Blazer in 97 the fuel lever sender is PN 25314231. Price at www.gmpartsdirect.com is now $60 plus their high shipping. About $120 at dealer price so I'd sure shop around. There are sender kits for about all the 97/98 GM vehicles too.
Old 12-19-2004, 08:46 PM
barpat96's Avatar
barpat96 barpat96 is offline
i have had my 97 blazer for 5 years now. the gas guage has never worked. I reset the trip odometer evry time i fill up and when i get around 250 i know i need to get gas soon. i've had the same problem on every chevy i have owned (87 Blazer, 94 Corsica) I don't think iwould know how to act with a fuel gauge that actually worked.
I don't think the Ignition switch would cause this but it being a 97 blazer, i would go ahead and replace it any way. save you some headaches later
Good Luck
Old 12-20-2004, 01:05 AM
i was actually about to ask how far can you go on a tank...how big are the '97 tanks anyway???
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Enkei 18" Rims
-Stinger Alternator
-Ripp Mods Header
