Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-16-2004, 09:50 PM
projectgsr's Avatar
projectgsr projectgsr is offline
CTR Pistons & GSR Rods?
Has anybody on this forum ever put Civic type R pistons in a GSR block without also changing the stock pistons? Do you think that's a bad idea? If so what would be my cheapest route to changing the rods?
Old 12-16-2004, 09:52 PM
projectgsr's Avatar
I'm sorry, I meant changing the stock connecting rods, not the pistons, twice, duh. I'm a little bit tired.
Old 12-16-2004, 10:22 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: CTR Pistons & GSR Rods?
You can use the stock B18C1 rods with the B16B pistons. But you will be landing in the 12.3-12.4:1 CR. Unless you have an wild set of cams your motor is going to be under cammed.
Old 12-16-2004, 10:29 PM
projectgsr's Avatar
What kinda cams do you suggest I get? Type R?
Old 12-18-2004, 08:01 PM
projectgsr's Avatar
Will there be any problem with me using pump gas (91-92 octane) with such high compression? Also which cams should I get?
Old 12-18-2004, 09:36 PM
whtteg's Avatar
I suggest ITR cams at the minimum and hondata or some other piggyback ECU setup. Then get it tuned, tuning is going to make or break a setup like that. Also 92 octane min.
