Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 12-16-2004, 08:29 PM
klone420 klone420 is offline
Question need alittle help please/tryin to get this done tonight
Takin apart my floating rotors and i'm havin trouble with separating the lower control arm from the steering knuckle balljoint. my problem is that i have a two-jaw puller but its alittle to big. I've put washers to space it out but i cant get it centered. I was wondering what i could use to space it better. my only idea is to take apart my skateboard and use the rubber spacers but before i do this can someone give my a few ideas so i don't have to destroy my board? I need to get this done tonight so i can get the rotors pressed in the morning. Also, why do cars have floating rotors? just to make shit harder than it has to be?
Any help would be great!
Old 12-16-2004, 09:34 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: need alittle help please/tryin to get this done tonight
Don't have an pickle fork do you? That would be a better tool to use but if you don't have one then I would try to put the 17mm socket I think it is (what ever fits the bolt on the lower balljoint). Put this socket on the bolt, make sure the bolt is run up until the end of the threads are even with the bottom of the bolt. Then see if the puller will reach it. If not the get the shortest extention you can find and see if it will fit in there. If not then take the socket off and try a deep well socket if you have one.
Old 12-16-2004, 09:48 PM
thanx, I don't have a pickle fork,but i'll try the socket with the puller.
Old 12-17-2004, 09:46 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Goto your local auto zone or parts store pick up a cheap 4$ pickle fork and you'll need a hammer. Honestly its much easier than anything else and 4$ is well worth the time and hassle you will save.
2002 Acura TL Type S
1991 Honda Crx Si
