Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-16-2004, 04:37 PM
wako528's Avatar
wako528 wako528 is offline
Talking B20 Crank ?
If I put a b20 crank with stock b20 rob and pistons in a gsr would that help tq or hp or nothing at all
In life there is a winner and a loser and i Am ALWAYS THE WINNER!!
Old 12-16-2004, 04:38 PM
wako528's Avatar
Re: B20 Crank ?
*rods
Old 12-16-2004, 04:40 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: B20 Crank ?
not sure if that can happen.... why dont you use the b18 crank and rods and get higher comp pistons?
Old 12-16-2004, 04:42 PM
wako528's Avatar
Re: B20 Crank ?
b20 crank has more stroke right ?
Old 12-16-2004, 05:52 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: B20 Crank ?
You could do it but....there will be alot more vibration in the sleeve than if you had a b18 crank in there. If you only revved to like 5 grand then it would be ok but when revving up higher to 8-9 grand warping will start to occur, it already does on a stock motor but it will be even worse and the motor's life span will be pretty short.
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-16-2004, 06:03 PM
wako528's Avatar
Re: B20 Crank ?
thnx so it wouldn't help with tq ? it just will make me car shake like a lawn mower so what crank would help with gaining tq ?
Old 12-16-2004, 06:08 PM
Re: B20 Crank ?
If your gonna mess with internals might as well just get a stroker kit or get a b20 block and put the gsr head on it.
1991 Honda Crx Si
Old 12-16-2004, 09:27 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: B20 Crank ?
The B20B crank is exactly the same as a B18B crank. The rods are the saem as well to, the pistons however will not fit unless you bore that motor out to 84mm.
Basically the B20B crank will stroke the B18C1 to 89mm vs 87.2mm of the B18C1 stock.
Old 12-16-2004, 11:34 PM
Ghost_R's Avatar
Ghost_R Ghost_R is offline
Re: B20 Crank ?
Just use the B18B crank, but vibrations will occur...
huhmmm.... go to spoonsports.com they have balanced/blueprinted cranks or crower.com, like go for the knife edged cranks.
Old 12-16-2004, 11:59 PM
Re: B20 Crank ?
whtteg if the b18b-b20 crank being the same comment was directed toward me I meant b18c as in stock crank.
If not then lol ok.
1991 Honda Crx Si
Old 12-17-2004, 09:37 AM
wako528's Avatar
Re: B20 Crank ?
where do the sell a stroker kit for a gsr motor
Old 12-17-2004, 09:49 AM
wako528's Avatar
Re: B20 Crank ?
*they
Old 12-17-2004, 02:36 PM
whtteg's Avatar
Re: Re: B20 Crank ?
If not then lol ok.
I was just giving some clearification, too many B18 comments with out specifing B18C or B18B
As for a stroker kit you can get one from Crower. I would stay away from this though, if you really want to increase the displacement then bore the B18C1 motor out to 84mm that will give you 1966cc as oposed to the 1797cc you have now, and you will keep your 1.58 R/S
Old 12-17-2004, 04:07 PM
wako528's Avatar
Re: B20 Crank ?
will that inprove tq or hp (I forget)
Old 12-17-2004, 04:10 PM
whtteg's Avatar
Re: Re: B20 Crank ?
Yes
