Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-16-2004, 04:20 PM
mustangfreak145 mustangfreak145 is offline
awd question
ok my friend wants to know about this. he has a 1997 awd turbo eclipse 5spd. his question is if he is moding it up (to like in the 650+ range) what would he need to replace in his transfer case? does he need to at all will it hold up? another friend had a eclipse like it and he had it for 9 months and it spent 6 months in the transmission shop so he sold it. are the transfer cases weak? or will it hold? thanks guys
Old 12-16-2004, 05:01 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: awd question
If you try to push 650hp out of the motor without doing a complete overhaul of the engine, the tranny is going to be the least of his worries!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-16-2004, 09:11 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: awd question
If he doesn't know already, then his goal 650 hp is out of the question
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 12-16-2004, 09:16 PM
2of9 2of9 is offline
Re: awd question
oh man...650 hp at the wheels is alot. He's goin to have to think about the whole car, the engine internals, externals, TRANNY, wheels, suspension, himself in that crazy beast, and the car. thats crazy!
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-17-2004, 03:07 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Re: awd question
I have a vid of a 715 wheel hp 1g eclipse tuned by AMS. I dont know what that has to do with anything but you could also ask over at Racing Knowledge Online, DSMTalk, DSMTuners, DSMetc, and others for more input. But I think there are some members on here who could help you. And do a search if you haven't.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 12-17-2004, 05:42 AM
ok ok he already has everything picked out for his car. he is doing internals tranny everything. all he needs to know is if the transfercase will hold up to that abuse
Old 12-17-2004, 01:32 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: awd question
transfor case will absolutly not hold up. what does he have picked out.
DSM geek
Old 12-17-2004, 01:50 PM
he is going to jackson automovie to get a 2.3l stroker kit and getting the block cleaned,sleved and preped for the stroker. race prep heads duel valve springs and the works. for thr transmission he is going to g-force to get there six speed that can handle 900 hp. get some kazz lsd's, a jackson auto intake manifold with 70mm throttle body, hks intercooler, and a giant turbo. but dont know how big. and a really tight suspention setup for road corces. this thing will be sweet. so the awd case wont hold up to this abuse? were can he find a awd transfer case that can?
Old 12-17-2004, 09:40 PM
ok idea
ok what if he gets a carbon fiber driveshaft,g-force racing transmission with clutch (6-spd), race axles. will it pick up the slack of a awd case or will it fail bad. need ideas bad. if i need awd transfer case were do i get one that can handle that kind of abuse? thanks
Old 12-18-2004, 01:05 AM
Re: awd question
I hope your friend has some DEEP pockets, cause this will cost EASILY $15k :o
95 GSX
Old 12-20-2004, 07:47 PM
Re: awd question
hey newb on this Info. Whats the Transfer Case? I'm guessing its the thing that holds the AWD all together..? LMAO, yeah..laugh at me, but what is it?
--2OF9--
#808/1000
Old 12-20-2004, 08:47 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: awd question
the transfer case bolts onto the transmission and is where the driveshaft to the back comes out.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-22-2004, 07:23 PM
rodknock rodknock is offline
Send a message via AIM to rodknock
Re: awd question
check out shepracing.com john sheppard's car runs 667 hp I think you can deffinately get the answer from them.
90/Talon TSI AWD/Manual
^^^^In most cases I am not a conformist, but I'm sick of the open ended questions as well.
Old 12-22-2004, 10:13 PM
Re: Re: awd question
Uh, he is well over 667 hp
95 GSX
Old 12-22-2004, 11:15 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
This is the answer. No speculation needed on anything else. If the guy doesn't know what to do about a transfer case, he sure as hell isn't going to be making anywhere near 600hp.
Secondly, why go to jackson for a stroker kit? What in the hell is a g-force tranny and why would anyone run that over a built stock 5 speed? For the record shep is running 800+whp.
If you actually have a friend that has 20 grand lying around, have him call a real shop and ask what to do. Don't bring up a g-force transmission or 600hp or they will laugh at you. Say you have too much money and want to build a fast dsm. RRE, SBR, magnus come to mind for shops.
