Old 12-16-2004, 03:59 PM
xmanmxp xmanmxp is offline
Battery keeps going dead
Hi. Could use some help. Have a '95 Chevy Astro Van. When i park it at night, it's fine. In the morning, it's dead and i have to jumpstart it. Have replaced the alternator. Also, took it to an electronics shop. Guy thought it was something to do with the doorswitch (on/off when you open the door). Finally, i've noticed that the dome lights come on by themselves in the middle of the night (and, sometimes, fail to shut off after automatically coming on when i park the car). Any suggestions would be appreciated.
Old 12-17-2004, 07:09 PM
hlfriesz hlfriesz is offline
Re: Battery keeps going dead
Did you ever have the battery check?
I had that problem long time ago and the shop told me the battery needs replacing, at that time I thought no way. Changed the battery and it fix my van. Have Autozone check the battery, I find them big helpers. And I need all the help I can get.
Hope this helps!
Old 12-17-2004, 07:55 PM
DCauffie's Avatar
DCauffie DCauffie is offline
Do the the dome lights come on w/ the dome switch in the off position??
1994 2wd Astro... 221,723 mi. Like New
Old 12-17-2004, 09:14 PM
thanks for the help. 1) had the battery replaced about 1 month ago.
2) re: dome light -- not sure which position is on/off. Switch doesn't work properly so usually it's in the ?out? position.
Old 01-02-2005, 11:05 PM
martyj1949 martyj1949 is offline
I've had this problem too.
I don't understand why anyone would design a car to act
like this, but it appears that if you push in the dome override
button (next to the light switch on my 1999 astro), the
dome light no longer comes on when opening the doors,
and the battery problem ceases.
Before this I had the same problem, and discovered that it
was the glove compartment light that wasnt turning off.
Look closely around the glove compartment opening, and
see if the light stays on. You may have to devise a way
to keep the switch button alligned with the part that it
is supposed to push against. I vaguely remember using
some contact cement and washers to fix mine.
