Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-16-2004, 03:57 PM
1Fast_Tsi's Avatar
1Fast_Tsi 1Fast_Tsi is offline
heat problems
With in the last couple weeks my heat would not work and would just be semi warm, and when i had my buddie look at it he told me that i needed a new waterpump, could that be why my heat was not hot it was just warm?
Red 90 tsi AWD 5speed
Love KIllin those V8's!!!!!!
Check me out at www.cardomain.com/id/1fast_tsi
Old 12-16-2004, 04:57 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: heat problems
Seems to me that if your water pump went out that your car would overheat. Sounds like your thermostat is stuck open. Is the car warming up to the temp that it normally does???
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-16-2004, 06:54 PM
1Fast_Tsi's Avatar
Re: heat problems
ya it warms up to the normal temp, if it was the thermostat it wouldnt even heat up. but i should get it back friday, i talked to him today and he had it done but he still had to put it back togeather, so friday i will see if it has heat or not, if it doesnt i think it might be the heater core or something.
