Old 12-16-2004, 01:29 PM
dwalmop dwalmop is offline
injector cleaner
Anybody have better luck using any particular type of injector cleaner over another? What are the best brands?
Thanks
Old 12-16-2004, 10:49 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
I really have never noticed any improvement when I use injector cleaner. Im sure it helps but to me they all seem the same. I did use some super strength carb cleaner in my caprice on time that worked a friggin miracle. Cant remember what it was called now. I had used all kinds of stuff in that thing, and none helped until I tried that stuff.
Old 12-17-2004, 07:17 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: injector cleaner
The best way is to use the 3M pro stuff that you connect to the injector rail, disable the pump, and let it run on the cleaner until it dies. That stuff works the best. You might be able to rent or borrow the hose assembly to connect it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-17-2004, 09:23 PM
huh, never heard of it. I'll have to look for it next time I go to the parts store. Thanks
Old 12-18-2004, 07:06 AM
It comes in a tall pressurized can that provides adequate fuel pressure for the rail, and the engine just runs off it alone. you have to disconnect your fuel pump, remember. It usually runs about 10-20 minutes on it before it is depleted.
Pretty cool stuff.
...empty gun rack.
Old 12-18-2004, 10:13 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
yeah, thats the best way to go, just make sure you pull the fuel pump fuse first. You want the car to only run on the injector cleaner. Just a question for you Jeff, is this stuff in any way harmfull to my cat converter, or my O2 sensor? Thanks
Old 12-19-2004, 07:32 AM
No, it is emissions control safe, and actually scrubs those parts to some extent. The danger is from products that leave a residue on the sensors. That causes them to become ineffective. The cat can only be poisoned by a few things, this isn't one of them.
...empty gun rack.
Old 12-19-2004, 10:23 AM
tblake's Avatar
In God We Trust
ok, thanks, I will defenatly try this stuff out in the future. My car is just too new yet to be worrying about it. Thanks again.
