3.4 intake manifold gasket
I smell radiator fluid out side of my car. have already replaced thermostat and switch and throttle body gasket. everyone says it's the intake manifold gasket. how do you replace?
Re: 3.4 intake manifold gasket
Take a look at this link
http://www.automotiveforums.com/vbul...=intake+gasket |
This is a copy of a previous post.......
My 2001 was having problems with Low Coolant indicator (no real loss of coolant) then temp gage started working intermittantly then finally went south. (Car was still running great) Dealer checked out and said intake manifold had leak. Looks like something going on, ended up dealer replaced sensors, thermostat and intake manifold gaskets (at least $600.00+ bucks) and did not charge me!!! I still have my mouth open.... car has 67000 mi said something about customer relations.... Not looking gift horse in mouth, but this was a first.... Check with your dealer may be a known problem they are trying to take care of.... Never hurts to ask....
Don't rule out the water pump. On my old 3.1 Lumina that went first, and that is an easy replacement.
All GM transverse 6 cylinders leak from the intake manifold it is a very common problem.
Re: This is a copy of a previous post.......
2002 Impala, 3.4L
3/9/05 @ 55k miles 9 registered trips to 4 dealers in Central PA - still looking for a good one!! 1. Intake gasket @ 52k - thanks dexcool, $800+ 2. Brakes @ ~10k, 15k, 25k, 40k, 50k - warping rotors - $250-350/each time. 3. Rear Doors hard to open - still an issue 4. Steering shaft - $220 (twice) 5. I had to replace some steering boots - clunking when turning at low speed (driveways, stop and turns) 6. Ignition switch @ 11k 7. And other parts I am sure I missed. Pros - I do like the ride, very comfortable - Cool styling Cons - Repairs, Repairs and more repairs. |
Add to that replacing the passenger side window regulator and you got it... I'm really tired of the repairs I'm had to do to my 2000 Impala. On the plus side, it does ride nice, is comfortable and gets better than average gas mileage.
just had lower intake gasket replaced free. the is a technical bulliten for this i believe they change the type of gasket. this is the second time for my car.
but hasnt cost me a dime. only other problems with my car a bad bcm, and noisey intermidiete steering shaft, wich i had relubed. |
Re: Re: 3.4 intake manifold gasket
2002 Impala, 3.4L 3/9/05 @ 55k miles 9 registered trips to 4 dealers in Central PA - still looking for a good one!! 1. Intake gasket @ 52k - thanks dexcool, $800+ 2. Brakes @ ~10k, 15k, 25k, 40k, 50k - warping rotors - $250-350/each time. 3. Rear Doors hard to open - still an issue 4. Steering shaft - $220 (twice) 5. I had to replace some steering boots - clunking when turning at low speed (driveways, stop and turns) 6. Ignition switch @ 11k 7. And other parts I am sure I missed. Pros - I do like the ride, very comfortable - Cool styling Cons - Repairs, Repairs and more repairs. |
Re: Re: Re: 3.4 intake manifold gasket
Re: Re: Re: Re: 3.4 intake manifold gasket
--> Shimmy and vibration from highway speeds with light braking. One time it was so bad the car was hard to control coming off the highway and almost shook me off the road. Took car to dealer the next day, dealer stated and I quote "the front rotors are warped and need replaced" -- $312.78 |
Re: Re: Re: Re: Re: 3.4 intake manifold gasket
Here is a good site to view customer data. http://gmproblems.com/brakes.htm |
