Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-16-2004, 08:04 AM
Panicis Panicis is offline
Tires
Presently have 215/70/15 on van for all season...Have 4 215/75/15 winter tires and 4 rims for the van....Will the tires fit without touching the body?
Old 12-16-2004, 08:05 AM
Re: Tires
Forgot...Tires are for a 2004 Montana...
Old 12-16-2004, 02:01 PM
Glen_T Glen_T is offline
Re: Tires
Check www.tirerack.com to see what they say. A 215/70/15 is 26.85 in diameter, and a 215/75/15 is a 27.70 in. diameter. So, you're about 8/10ths of an inch bigger in diameter, and I don't know if that will cause problems. A 205/75/15 would probably be a better fit - skinnier but slightly larger in OD (27.11). However I'm not positive, and I seem to recall tirerack having a feature that tells you what sizes will fit....good luck, Glen
Old 12-19-2004, 02:15 PM
tmorris1 tmorris1 is offline
Yes they will work. I had a set that size on my 98 montana.
