Old 12-16-2004, 06:11 AM
deadring deadring is offline
Question Climate control, a bug or normal?
hi,
i got a PA SC 92 ... i got the climate control in it.. which i think was stadard in an ultra.. anyways, when it gets real cold, i adjust the heat to 32 degrees celsius ( max) and put it on the second on third fan speed and put it on DEFROST before i stop the car...( hey, it's winter here!), you know to give the engine a chance to warm up too when i start it with the remote...but for some reason,when i start the car with the remote, the car has a diffrent idea, it puts it self in AUTO mode and full temperature, and full fan speed... it does it ( or seems to) when its cold.. like below -10 degrees celsius/ 14 degrees F
now is that a feature of a bug?
Deadring
Old 12-16-2004, 02:48 PM
parkavenuechrome parkavenuechrome is offline
It is normal deadring. It makes the inside of the car warm up to the temp setting you set it to. Perfectly normal...
Old 12-16-2004, 08:46 PM
Re: Climate control, a bug or normal?
no no, i know what a climate control can do..
i forgot to say that ...hmmm heres an example for ya:
last night i set the car at 27 degrees celsius and the fan speed at 3 and put it on ECONO
next morning i start the car by remote , when i get in the car, its at AUTO, at 32 degrees ( max temp) and the fan is a MAX...it's like theres a glitch at startup it momentarly removes the juice on the cliamte control and... well.. it makes exactly like you unplug the battery.. but does it only when cold...
OR
it's normal that after a certain degree of temperature, it does that to warm up the interiror of the car
i dunno...
deadring
Old 12-17-2004, 09:00 AM
Re: Re: Climate control, a bug or normal?
OR
i dunno...
deadring
yea i know what your saying.. Its normal.. if you start it with the key, then it stays.. all normal...
Old 12-17-2004, 09:06 AM
hehehe i can't believe this is normal feature
thanks
