I have been experiencing a rather annoying noise from the transfer case area, in my 93 jgc v8 quadtrac, i can feel the vibration in the 4wd handle, and if i move it just an 1/2 inch or so in any direction it gets worse. my local trans. shop said it could be the linkage in the case loose and hitting the case, any other ideas before i change it out. also anyone have a link that shows the removal and replacement procedure of the trans case.
thanks much.
B.Allison 93 JGC Lmt quadtac v8 156000 miles |
Re: whining or rubbing noise from transfer case
When does this happen, in gear or inbetween neutral and reverse? These models had a problem with niose resinating from the transmission. there is a recall on it, though I don't think its grandfathered. I worked on a freinds that did this. changed the fluid and filter and the sound went away. Also you might try changing the T-case fluid, I used synthetic, worked great.
this does this at speeds around 20 mph and over you can feel it in the shift lever for the 4wd, comes and goes. when you hear it you can feel the jeep pull to one side and when making a slow speed sharp turns the front ends hopes like in low range. it seems like it takes more throttle than normal and guzzles the gas.
is it the NP249 tcase??
yes it is the np249
current rides: 1990 Turbo Miata lifted and locked 96 Grand Cherokee with other toys under the hood retired rides: 1996 Eclipse GSX 1991 Stealth 1991 Porsche 993 C2 1988 BMW 520i Your SUV isn't a Jeep, and my Jeep isn't an SUV.... SCCA, where you actually learn to drive |
why you say that
the 249 is not exactly the tcase of choice. very problematic.
