Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 12-16-2004, 03:20 AM
tom coleman tom coleman is offline
96 toyota tercel-charging problem
96 toyota tercel-alternator not charging battery. had checked and replaced alternator and belt last week. had same problem since-at night it seems alternator not charging enough and starts running off of battery, which soon drains. have had everything checked-alternator charging okay, battery okay, no power drains, etc., but still having problem every night.
Old 01-02-2005, 04:14 AM
b_azadeh b_azadeh is offline
Check all wires for continuity and/or short. If the alternator is working hard it is a shorting problem, and if it not carring a load it is a continuity problem. You know how if you turn on your defogger and the engine rpm reduces, that is a sign of a load, and if your engine/ alternator feels and sounds like that then chances are it a shorting problem. Have you checked all the fuses and breakers?
Cheers
