Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-15-2004, 11:26 PM
stephx0x0x stephx0x0x is offline
Send a message via AIM to stephx0x0x Send a message via Yahoo to stephx0x0x
Turns off while in reverse
My 95 Contour, while in reverse turns off to where its just the radio is on, I will turn it off completely and try again and it will do it again once or twice. Does anyone know what could be wrong with it? Thanks.
Old 12-16-2004, 01:33 PM
Jason43's Avatar
Jason43 Jason43 is offline
Re: Turns off while in reverse
Can you give a little more info about your car? V6, 4 cyl, manual, stick etc...
Just go to contour.org
1999 Ford Contour SVT
Old 12-17-2004, 04:04 PM
JimR's Avatar
JimR JimR is offline
ya we need lots more info about your trans. and engine
Old 01-06-2005, 11:19 PM
My car is 4 cyl, automatic trans and 2.0
Old 01-07-2005, 07:43 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Check your battery cables especially the positive cable and the positive cable that connects to some remote positive cable terminal. Just trace the battery terminal cables connections and make sure they are tight.
Sometimes when the gear is moved in reverse or forward, it also moves the engine slightly if the motor mounts are weak. The engine movement might be enough to make the electrical cables not 100% in contact but just enough to supply electricity to low power accessories.
Old 01-10-2005, 04:20 PM
oh ok thanks...ill try that and see what happens
