Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-15-2004, 11:11 PM
Knightmare2oo5 Knightmare2oo5 is offline
Exclamation Radio stays on without key (Battery Drain!!)
I have an 90 honda accord and my radio stays on after I take the keys out of my ignition but i want it to turn off when i take out my keys like a regular car does so it will stop killing my batteries. can anyone explain the wire hook up (i have a harness) thanks
Old 12-16-2004, 04:20 AM
Integrity1's Avatar
Integrity1 Integrity1 is offline
Re: Radio stays on without key (Battery Drain!!)
Cut the wire from the stock harness and mate it with the proper 1's on the head unit.
Look what I can do!
Old 12-16-2004, 07:00 AM
i dont understand
Old 12-16-2004, 07:57 AM
Aperson Aperson is offline
Think what he's saying is that you have the wires connecting to your head unit crossed. Sounds like the constant 12V wire from the battery is crossed with the 12V intermittent...check the wire harness
_____________________________________
"If you stop to listen to all the advice in the world, you'll end up doing nothin." -Aperson
Old 12-16-2004, 09:57 AM
can explain which colors connect with what because how i had it at first I :connected the 2 memory 12volts together(yellow) to ground wires together(black) and the 2 accessorie/ignitions together(red) then i connected the reds and the yellows together thats how i had it and it stays on
Old 12-16-2004, 11:38 AM
xtant's Avatar
xtant xtant is offline
Re: Re: Radio stays on without key (Battery Drain!!)
the red and yellow should not be together. The red goes on and off with your key while the yellow is your constant 12v (memory)
Josh
Old 12-27-2004, 08:07 PM
now it blows my fuse in the choke box
Old 12-27-2004, 08:30 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
now??? You can't cross the two wires, whatever said to do that was lying. The yellow(from car) is the constant power and since the yellow is connected to both Yellow and Red(on HU harness) the headunit it is always seeing the ignition as being on. You need to uncross those two wires and your problem will be solved.
John 3:3
Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God."
Old 12-27-2004, 08:53 PM
an hour ago I hooked each color to color and this time i didnt cross the yellows and red and the fuse still blew
Old 12-28-2004, 05:00 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
lol.. DO NOT CONNECT ANY WIRES TOGETHER!!!! uncrimp them, and tape up the exposed wires... he said to just check the yellow and red wires on the head unit harness.. trace them back to the ignition and be sure they do not cross each other to complete a circuit. patch them if you need to, or run new wires, to rid yourself of the problem completely..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-28-2004, 08:14 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Do you have a multimeter? If so measure the voltage(DC) of the red wire. It shoudl be 0 when the ignition is off and 12-14 when its on. The yellow should always read 12-14. If you have everytihng hooked up correctly and its blowing the fuse check past the harness, make sure no bare wires have been exposed and also check there are no shorts with the cigg ligher. its on the same fuse as the radio.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
