1st grinding , 2nd , 3rd 4th and 5th nothing
Ok here's the situation....The car is a 1993 Mitsubishi 3000 Gt with 85,000 miles . First things first , after i start the car and release the clutch, the clutch comes up and stops about half way then hesitates. When i start the car in 1st its stalls , if i start it in neutral it runs fine but 1 st gear grinds and it wont even begin to go in to any other gear.
If anybody else has run across this problem , please help , I'de hate to replace the clutch if the master or slave cylinders are at fault. Any input would be greatly appreciated. Thanks. |
Car Images
Re: 1st grinding , 2nd , 3rd 4th and 5th nothing
that defiantely sounds like a hydraulic problem.
my bet would be slave cylinder leaking but you need to check it out. check your fluid level 1st by prising off the top on the clutch master cylinder next to your washer bottle. if its low chaces are the seals inside the slave cylinder are shot. if you need anymore help, mail me and i will talk you through the process. BB
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!! 9b turbos with manual boost valve mod set @14psi turbo xs type h-rfl blow off valve blitz dome filter sachs clutch completely de-catted fuel pump voltage rewire mod ebc redstuff front brake pads greddy fully automatic turbo timer now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
must not be it
We checked the level of the fluid and it seems to be fine. Do you or anyone else have any other ideas what it could be?
something in the lines may be jammed up.... flush the lines and see.
____________________________ ______________________________
agreed, sounds like hydraulic problem. visit www.stealth316.com and there are instructions for bleeding the hydraulic clutch lines (master/slave cylinders). that would be my suggestion. air bubbles in the lines could cause this problem, but also, your master adn/or slave cylinder(s) could have just failed and broke. in which case, you would obviously need to replace them. follow instructions at stealth316.com, then if no luck, take it to a tranny shop.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Here is my update:
The master cylinder was replaced but the car wasn't fixed. The guy working on my car thinks the problem is with the clutch arm, fingers in the pressure plate, or just the pressure plate itself but he is not sure. So the mystery remains. Hopefully he will figure it out when he takes it to his shop. |
I hope he gets to the bottom of the problem in short order. Its looking like a really bizzare situation.
Resistance Is Futile (If < 1ohm) |
The guy found the problem. It was the throwout bearing that was broke. I'm just going to get a whole new clutch kit put in. It's costing me almost 700 but the guy I bought it from said he'll pay half since it broke right after I bought it...so hopefully I'll be getting my car back within a day or two. I haven't been able to drive it for 2 1/2 weeks.
