Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 12-15-2004, 09:08 PM
notkidding notkidding is offline
Rough idle/starts bad
I have a 1999 Passat. When I start the car it barley starts. Then I have to let it idle (very rough) before I can start driving it. When I first start driving it It will bog down even if I have it at full throttle. It sits there for like 3 seconds or so then it takes off and runs fine until I come to a stop again. Then the same thing happens. After I have driven it for awhile it doesn't do this anymore. The check engine light comes on every now and then. I just had the turbo and the timming belt changed on it. Could this problem be from the turbo going out and damaging the O2 sensors? Any other ideas?
Old 12-16-2004, 03:28 PM
boschmann boschmann is offline
Re: Rough idle/starts bad
You need to have the codes read. It might be best to clear them, restart the engine & check them again.
Old 12-18-2004, 12:55 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like a Throttle body. or MAF sensor. More likely a throttle body.
