Old 12-15-2004, 08:07 PM
speedstur speedstur is offline
Progress: Lone Fish
I decided to start a new fast paced project called lone fidh. I'm starting woth the revell 71' Hemi Cuda. The main feature of this car will be the A pillar chop but the overall goal will to be to keep it clean and stream lined.
Before Chop
After
I'll get some more done tonight and post it up tomorrow. What do you think?
^Click^
www.rocketrob.com
Old 12-15-2004, 08:15 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
im not sure what your trying to do? lower the windshield stance?
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 12-15-2004, 08:22 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Progress: Lone Fish
interesting chop top.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-16-2004, 12:58 AM
_WIDE_LOAD_'s Avatar
_WIDE_LOAD_ _WIDE_LOAD_ is offline
Send a message via MSN to _WIDE_LOAD_
A pillar chops were popular in the early-mid 80's from what ive heard. This is gonna be a interesting project.
I'm waiting with baited (no pun intended) breath for some more progress.
Later, Troy
My name's Troy, use it if you like.
If you're a Buddist, you go to Tibet....If you're a speed freak you go to the Salt Flats
351 clevo....aussie muscle
Old 12-16-2004, 05:36 AM
primera man's Avatar
"P-Man"
View All My Models Here.
Old 12-16-2004, 05:00 PM
Thanks everyone, Im attempting to give the car a more streamlined lean towards the front by only chopping the a pillars.I managed to get the gap filled with some styrene and the hood pins sanded off.
^Click^
www.rocketrob.com
Old 12-17-2004, 10:16 PM
A little more done, I shaved the door handles, lower trim piece and ts markers. I also puttied it all up.
The back was also cleaned up.
What do you think?
^Click^
www.rocketrob.com
Old 12-22-2004, 07:30 PM
I got evey thing sanded down so tomorrow I will be painting it.
Here you can see how thw suspension lean complements the chop.
To use the wheels and tires I wanted it would require a larger wheel well. At first I wasn't quite sure on how to make them, then I found a solution when I went to take some tylonol. The bottle would be a perfect shape.
As a result of the larger wheel wells I had to remove the rear seats and I'm now working on patching it up.
What do you think?
^Click^
www.rocketrob.com
Old 12-22-2004, 08:27 PM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
tubes look good
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 12-22-2004, 08:57 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Very creative tubbing. Can't wait to see more.
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 12-22-2004, 11:15 PM
spitfire143 spitfire143 is offline
another useful tub source i've heard about and used is the inside of paint can's caps.
The car is coming together nicely!!!
Old 12-23-2004, 02:53 AM
Wheelin75r's Avatar
Wheelin75r Wheelin75r is offline
Great idea. The stance looks awesome!
Old 07-25-2005, 12:20 AM
Finally got time to go back to modeling after moving and working on the new house. I sanded down most of the stuff than just sprayed on some primer to see how much work still needed to be done ond to my suprise its not that much. I hope to be putting on the color sometime this week.
^Click^
www.rocketrob.com
Old 07-25-2005, 01:28 AM
Sigmaman's Avatar
Sigmaman Sigmaman is offline
AF Premium User
Send a message via MSN to Sigmaman
Looks really good .The a pillar chop is sometimes known as the gentlemans chop.Don't know where that name came from though.I tried this on a plymouth superbird slot car I built once.Worked out quite well.
www.sigmamansmodels.com
Old 07-25-2005, 05:38 AM
Amazon's Avatar
Amazon Amazon is offline
Correct me if i´m wrong, but doesn´t a `gentlemans chop`also include the cutting of the B-pillar? Just so it comes loose ( not removing material) and getting a better flow in the roofline?
Newsflash: Diecast sales fund terror activities.
