Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 12-15-2004, 08:07 PM
dblj6 dblj6 is offline
fuel gauge always reading full
Hi,
has anybody had fuel gauge constantly reading 3/4-full all the time?
thanks
Old 01-07-2005, 12:32 AM
DALEGD1 DALEGD1 is offline
Re: fuel gauge always reading full
Hi
I had this problem after I changed my fuel pump. The float got bent and hung ip on the baffle inside the tank
Old 01-07-2005, 01:36 PM
harley2 harley2 is offline
Hi lately my gas gauge does not read the correct measurements it goes from half to empty usually after i put gas in it or i am at a idle it will go straight to empty and the low fuel light comes on?
Old 01-12-2005, 06:39 PM
gkh7890 gkh7890 is offline
Most likely, you have a bad sending unit. This is attached to the side of the fuel pump which is inside the gas tank. The sending unit alone at GM costs about $135. You can buy the whole pump assembly w/ sending unit on Ebay - - PAY attention to your part number.
To replace it (yourself), either take off the bed OR drop the tank. For $15.00 I'd buy a Chiltons manual...it has paid off many times over for me now. It walks you thru the process of dropping the tank, step-by-step. I just replaced the sending unit in my '00 Chevy Express van. I dropped the tank on that job. If you do drop the tank, run it down as far as you can (where the light would come on normally - which indicates there is about 4 gallons in the tank). Change your fuel filter at this time (if you drop the tank).
My guage has gone bad as well and I'm getting ready to replace mine.
