Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-15-2004, 08:02 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
steam clean
anyone ever heard of steam cleaning your engine? kinda sounds weird but i was talking to my friend a while back and he said he was going to take his mx-6 in and get the engine steam cleaned because its pretty shitty and he wants to make it into a project car, so the engine is really greasy and dirty. he said it only costs like $20??? ive heard of steam cleaning the mfukin carpet, but the engine?
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 12-15-2004, 08:04 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: steam clean
ya it works great, just be sure to cover electrical connections
Old 12-15-2004, 08:22 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: steam clean
or buy some degreaser for $5, take it to a car wash where you can wash you car yourself, spray the degreaser where you want cleanliness, and pressure wash off. the only shitty thing is that you have to be REALLY careful cause if you do it wrong, your engine won't start very well if at all.. don't go over any electrical parts.. basically you can spray parts of the engine, the walls of the engine bay, the hood.. and thats about it.. its also good to use an air hose to spray out the moisture right after. but that may not be as accessible to you.. just a suggestion
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 12-15-2004, 09:08 PM
Tims_240's Avatar
Re: steam clean
but if i take it to have it done, they should cover the electrical stuff right?
.s13 power.
Old 12-16-2004, 05:43 PM
D-Bo's Avatar
Re: steam clean
if you take it to be done they'll know how to do it properly.. i did engine shampoos all the time at work and after a while i knew which parts shouldn't be shampooed and which should.. so the people who do it for you will know what can be cleaned. the shampoos are great though.. keeps the engine bay clean of anything that could corrode wires, tubing, the body or the engine itself.. they won't cover the electrical stuff though, they'll be good enough at it to avoid spraying it all
Old 12-16-2004, 10:22 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Re: steam clean
Where would you get this sort of thing done? Detailing shops? Body shops?
Old 12-17-2004, 12:04 AM
D-Bo's Avatar
Re: steam clean
any car dealership, but i'd stick to the same make as your car (go to a nissan dealership).. pretty much any garage with a pressure washer can do it cause they obviously all have degreaser but its whether or not they know how to do it properly.. and detailing shops do them as well but sometimes they have employees who work there just to make some cash.. its not THAT big of a deal if you get some parts wet but find somewhere with guys who will do their best to get the right parts.. as for body shops, probably not but you never know..
Old 12-17-2004, 12:10 AM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
Re: steam clean
yea a friend of mine got it done at a local toyota dealership. Just ask around.. it's not hard to find...
results? eh... i admit the engine bay got cleaner but it's nothing like the *new* look. Of course, it really depends on who's doing the work for you....
Old 12-17-2004, 12:41 AM
D-Bo's Avatar
Re: steam clean
and it depends on what kind of shape your bay is in!
Old 12-17-2004, 02:40 PM
Tims_240's Avatar
Re: steam clean
what are all of the parts to you need to cover, because i have a pressure washer.
.s13 power.
Old 12-17-2004, 03:38 PM
D-Bo's Avatar
Re: steam clean
ummmmmm.. well put it this way. wash the valve cover, all the walls in the bay, hood, any plastic and if you can the outside of the engine block. keep control of your pressure washer and aim it so the backspray doesn't hit any of the electrical parts. and if you have an aftermarket intake with a visible filter, DON'T GET THAT WET. if you do then i would highly reccommend letting it sit in the sun for an hour to dry off
