car vibrating////
my 97 has a slight shake in the steering wheel at 180km/hr...any suggestions??? besides slowing down i mean//////////// got tires balances seemed to help a little but still there....
Re: car vibrating////
sounds like bent rotor
should get an alignment too
*Better power-to-weight ratio than a C6 corvette* Last edited by Chevyracincamaro; 12-16-2004 at 11:12 AM. |
Re: Re: car vibrating////
When I changed my brakes ( had the vibe. ) I noticed the brakes were worn well beyond the wear indicators ( Which is what makes them begin to squeal. but is really just a peg to hold them together.) The wear indicators had worn into the rotor and it was no longer even , I put new pads on but the vibes were still there. I had to change rotors and the what not. No vibes nowfor the last 10K...Just a thought.
I love rice so much , I eat it daily. Yum yum Civic. 1992 RS Camaro 383. 2004 Mazda 6. 2003 Subaru Legacy GT Limited. 1984 Nissan 300 ZX 1993 Mazda MX-3 ( Newest addition to my collection. ) http://photobucket.com/albums/y187/ohjiro |
yeah, basically what happens is the rotor wears in one section of the arc more than in another. this section is less than the rest of the rotor causing it to 'rattle' back and forth as you apply brake pressure. this makes the whole car shake as the entire front suspension is tied into the front brakes. you replace the rotors and the problem goes away...
*Better power-to-weight ratio than a C6 corvette* |
Shake, Rattle And Roll
Since it is speed dependent and you did not mention any thing about the problem increasing when you apply the brakes it is not a bent/warped rotor. You need to mention if it happens while you are in neutral at the problem speed. . § §§§§§§§§§§§§§§§§§§§§§§§§§§§§§ REFUSE . TO . LOSE § §§§§§§§§§§§§§§§§§§§§§§§§§§§§§
no shaking when i brake guys its when i'm accelerating
If it's still happening , Maybe go with the quick and easy U-joint replacement.
