Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-15-2004, 07:09 PM
mugengaia mugengaia is offline
Need help on engine swap please~!!!
OK, so I look forward to swaping my 93 model si engine to a V-tec.
What I would like to know is...could I mount a Prelude Type-S H22A (97-01) engine into my 93 prelude???
I was thinking maybe there may be a way to put that thing in with adjustments like mounts and stuff?
I mean, I would really like to get that extra 20hp boost if possible, cause I'm currently thinking of adding a 4th gen turbo kit.
Well, there's my question...I hope soemone can help me out here...
Old 12-15-2004, 11:32 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
Re: Need help on engine swap please~!!!
yes but not worth the extra hassle of making the torque -split system work right. I beleive you can make-up for the extra horses with bolt-ons and ecu tuning. An LSD tranny would be ideal if you have alittle extra $$$ to spend. In the process, you might as well upgrade your drivetrain components(clutch/press plate/flywheel etc) and you'll be glad when you finally throw your turbo on.
Then from what ive seen so far, its best to use a H23 block for boost applications because of its closed deck design which makes the sleeves stronger. I'm yet to reasearch more on this tho! still a H-series noob!
Good luck!
Old 12-16-2004, 01:48 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
If you must, buy the Type R H22A (Type SiR). It comes with the 220hp without the hassle of ATTS.. plus you get the factory limited slip differential.
SiR H22A -> 220hp LSD
Type S H22A -> 220hp ATTS
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 12-16-2004, 07:09 PM
funny...could you help me out here?
I looked at what JDM has to offer and doesn't seem like they have any Type-R (SiR) H22A.
Old 12-22-2004, 07:41 PM
yeah, you'll need to look a little harder for those, lol!
Old 12-22-2004, 07:45 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Re: Need help on engine swap please~!!!
the 92-96 h22a1's were also closed deck.
Old 12-23-2004, 12:04 AM
yeah, those too were closed deck, thanks. Easy way out but if you have a H22 apart, might as well use proper sleeves($$$) or block guard(cheap!)
Old 12-23-2004, 12:11 AM
SiGNAL748's Avatar
Yeah, i'd resleeve regardless of it being open or closed. It'll yield best results when you decide you don't have enough boost and are hungry for more
Old 12-24-2004, 12:47 AM
jwd3jdm jwd3jdm is offline
The SiR h22a is just the regular jdm vtec motor with 200hp and lsd tranny.
You're right about the type s, the only other h22 that comes with 220hp is the h22a8 that comes out of an accord euro r and it has the true lsd tranny and better gearing so out of the two 220hp h22's the euro r is the better buy. Also if you are planning on turboing your motor, the SiR motor is the best. The type s and the euro r make their 20 extra horses with better cams for a naturally aspirated motor and higher compression which is not what you want for a turboed motor. You are going to end up redoing alot more to get more hp out of those. Definitely get the lsd tranny though, you'll want it!!!
