Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-15-2004, 06:51 PM
tbsc tbsc is offline
Lightbulb Hello all> "oh no" wife wont's a new car & the baby need well
Thank you for your input.
1990 thunderbird sc will not run.
the car has 88950 mile on it 3.8 v6 sc went out and got me one of thouse code readers. hocked it up it said code 21 ect sensor I put a new one in won't start. code 24 tp sensor put one in won't start.
hummm I will do a tune up a good one all the way you no. a new coil new spark plugs checked fuel pressure 45 good checked fireing ok.
fuel injector resistance good 13.5 I am geting some gas in oil not alot but some. ol replaced icm pcm eec-v5 crankshaft position sensor and camshaft sensor. Won't start.
Help please and thank you
Old 12-17-2004, 11:50 PM
speed95 speed95 is offline
Send a message via AIM to speed95 Send a message via Yahoo to speed95
I was having problems with my bird not running too. I had a guy here in houston hook it up on the computer and he said my temperature and camshaft sensor went out. Now it runs great. Try turning the key forward and pressing the gas all the way down and then start it. But make sure u turn the key to the on position b4 u press the gas. If it starts for u it might be the same thing as mine. Dont know if it will work but its something to start with
Old 12-21-2004, 08:48 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Hello all> "oh no" wife wont's a new car & the baby need well
Have you replaced the spark plugs? I can't tell by your post if you have or are going to. Take the plugs out and see if they are wet with gas. If they are there is either no spark or a very weak one. Since you replaced the tp sensor do any other codes show up? While you have the plugs out do a compression test. Auto Zone has compression testers for rent. When you return them you get your money back.
