Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-15-2004, 05:02 PM
spanky9929 spanky9929 is offline
Send a message via AIM to spanky9929
engine swap
ok heres the problem i got i have a motor out of an automatic and want to know if there is some way to make the engine work with my 5 gear i was told that it wouldn't work but thought maybe someone could tell me some way to make it work by the way it's a 1.8l can this be done
Old 12-15-2004, 07:30 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: auto to 5 speed
it should work fine. use the clutch, flywheel, starter and everything from the 5 speed. you will probably also need the metal dust sheild that matches the transmission. im not sure what the real name of it is but the sheild that goes in between the engine and trans.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-26-2004, 01:36 PM
emoontheinside emoontheinside is offline
Send a message via AIM to emoontheinside
Out of curiosity, about how much would it cost to turn my auto 2.0l into a 5 speed? I've heard anywhere from as low at 500 if I do it myself (which sounds really insanely low) to as much as 3000 if I take it to a shop and have them do it to be on the safe side.
Old 12-26-2004, 04:29 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: auto to 5 speed
you could do it for 500 with a junkyard transmission and a cheapass clutch. But its not something that you could do yourself if you've never even taken a transmission out of a car that's already a manual though (its not a job for beginners)
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-26-2004, 07:41 PM
Re: auto to 5 speed
you need more then just the transmission. you need all the shifter linkages the trans, the clutch pedal assembly, the clutch hydralics, you probably need to hack the wiring for the transmission too.
-1stGenRocks-
Old 01-10-2005, 04:33 AM
Reager Reager is offline
Re: auto to 5 speed
Having a friend do this job to a 90 Laser I can say its not a fun task. As before stated you will need everything involved in the tranny. Your best bet would be to check a junkyard for one thats been recently wrecked, or try to find a car with a blown engine.
Work will take at least a couple days even if you have a few sets of hands. Doing the job yourself with no prior knowledge would be very bad, so I wouldnt recommend that unless you have a friend thats a mechanic.
