Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 12-15-2004, 03:56 PM
chadsdc chadsdc is offline
Exclamation engine quitting after warm up
93 olds achevia seems to run fine when cold but after warm up it will die on the highway and will not start for a few minutes and then only runs enough to move about 20 ft and will also stall in the garage at higher idle
not giving me any codes
just replaced coil housing spark plugs and boots because of a miss problem but that cured it now it will stall
it is a 4 cly 2.3 dohc ant suggestions thanks
Chad
Old 01-18-2005, 10:54 PM
jeniveeve jeniveeve is offline
Sounds similar to what our 93 does.... did you check the idle air control module?
Old 01-19-2005, 03:17 PM
yes but it turned out to be the crank sensor
