Old 12-15-2004, 03:50 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
distributor?
i thought i figured out my problem with sputtering at WOT in the lower rpms and all but i guess i didnt. i got new plugs, new wires, changed my distributor cap about 3 months ago, changed my rotor two weeks ago, changed my ignition coil 3 months ago. and now when i go to start my car up, it cranks normally for a little bit and then my engine like misfires as its starting up. it takes a few tries for my car to start up and on crank it misfires. its way below freezing out, could that be the problem? also, my car still sputters at WOT in the lower rpms. could it be my distributor going bad? its just annoying me now.
Old 12-15-2004, 11:23 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: distributor?
distributors really dont go bad that often,
unless like one of them teeth things break inside of it,then you'll know somethings wrong,
sputtering is usally caused by fuel,
an air/fuel ratio guage would do nice!
you might want to try changing that fuel filter if you havent in a while,
it also could be caused from a lazy fuel pump,
I would check the fuel injectors,ait sensor & havc(somthing like that,I dont know why I dont remember,what its called)
with an ohm meter,
one of them should be the problem,sputterings not a serious issue when fixing it,its usally just one thing messed up,
good luck
In the process of B00stin my D
Old 12-16-2004, 12:04 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: distributor?
do you ever have situations where the car turns over and over and over, but wont seem to fire up for anything? especially when its hot outside?
if so, its either the main relay or the sensors inside the distributor.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-16-2004, 05:31 AM
vladlos's Avatar
Re: distributor?
the problem with the misfiring on crank thing only started recently......so i'm not sure if it would do the same in the hot weather. oh yea, i changed my fuel filter 2 months ago, too.
Old 12-16-2004, 10:07 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: distributor?
take the distro cap off and check the contacts on the inside, maybe one of just got corroded somehow and the rotor is not firing that cylinder.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-16-2004, 04:58 PM
fgiblin fgiblin is offline
Re: Re: distributor?
What DOES go bad on these dizzies are the electrical parts. The coil or the igniter (ignition module) are both inside the distributor. My problems with them have caused hard starting, weird surges at high rpms, misfires at low rpms, even engine shut down on the highway. And the electrical parts are affected by heat so they can act very differently at different times -- often the problems are too intermittent to even have a mechanic help you out with. Sometimes it will throw a code for the igniter (like when my engine shut down - it would eventually restart) but sometimes not.
In my experience, if the problem is pretty inconsistent (ie. mechanical parts don't break and then unbreak, and fuel filters don't clog and then unclog), maddening, I start looking at these parts. Sensors and injectors and all that are possible suspects but beyond my ability to test or replace anyway. So I knock out the easy parts first and try to save myself a trip to the garage. So far, so good.
One thing too: eventually the distributors on these things do wear out (some have said to watch for white powder inside the cap as the parts break down). As the shaft or other parts start generating more heat, they generage more friction and that can cause the electrical failures.
So far, I've replaced my coil once and the igniter twice. Now the car is running fine but I just ordered a new dizzy b/c I think it's on it's way out.
HOPE THIS HELPS!!
Old 12-16-2004, 05:07 PM
vladlos's Avatar
Re: distributor?
when i replaced the distributor cap a few months ago it had all kinds of crap in there on the contacts. mostly black burnt stuff. i'm gonna go check it out again.
