Old 12-15-2004, 03:09 PM
G35turbo G35turbo is offline
Transmission Question?
Ok, I drive a 97 VR-4 and everytime i want to go from 2nd to 3rd gear when racing it feels like it dosent want to go into 3rd gear and it kind kicks back, and i have to kinda forced it in. Some people told me that my syncro is going out. Also i havent taken to the dealer for the Transfer case recall. So do u guys think is the transfer case, or is there something wrong with my whole transmission.
Also my clutch just went out and i havent got the new clutch yet, do u guys think it could be the clutch that dose that and when i put my new clutch in, would that fix the problem?
Please Help ASAP
Thank You
Old 12-15-2004, 03:36 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Transmission Question?
fix your clutch first and then go from there.
does it grind when going into to gears, or it just simply wont let you in? or what
Old 12-15-2004, 09:34 PM
It lets me go in but it feels like it dosent want to go and i have to kinda force it in. But it just mostly dose it when i am racing somebody and i am like 5500rpm or 6krpm and i am changin from 2nd to 3rd. It sometimes when drivin normanl it dose that do. Ohh and when the car is cold it feels like it dosent want to go to any gear. I dont know what the hell is up with that but when the car is warmer it works fine and i just done the 60k mile tune up and they changed my transmission oil.
Old 12-15-2004, 09:41 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
when its cold its normal for it to not want to go into gears, the oil needs to warm up first
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-15-2004, 10:05 PM
How about the other problems?
What do u think is the problem?
Thank You
Old 12-18-2004, 12:30 PM
Hotshot8792 Hotshot8792 is offline
shifter bushing has probably gone bad, i believe you can buy a new one from the dsm community somewhere for 20 bucks
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 12-18-2004, 06:04 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
you can take it to a tranny shop; they could properly diagnose the problem. but before you jump to conclusions, check the shifter cables, but my money is on the master and/or slave cylinders. when i THOUGHT my clutch was going out, it was hard to shift into some gears, but i had to force it to get it to go in (like you described). turns out, it was the slave cylinder that had developed a leak. i replaced it, but also had a new clutch put in since it was 12 yrs old and hadn't been replaced in 65K miles.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-19-2004, 03:10 AM
How much was the slave cylinder?? what happens if i keep dirvin the car? would like fuck up my tranny or is it going to be ok?
Old 12-19-2004, 01:02 PM
Where is the Shifter cabels and how can i check them?
Old 12-20-2004, 10:18 AM
Linebckr49's Avatar
slave cylinder is pretty cheap...around 50 bucks. check out www.thepartsbin.com for parts-->good prices and free shipping over $50 orders. i get most of my parts from there.
if you kept driving your car like it is now, by forcing it into gear, then you'll probably start grinding your gears (if you haven't done so a little already). continued use like this could really f*#k up your tranny. stop now! take it to a tranny shop.
93 3000GT base
Old 12-23-2004, 08:28 PM
How do u know if your griniding your gears?????
Old 12-29-2004, 02:22 AM
Retard324 Retard324 is offline
Send a message via AIM to Retard324
it makes a loud grind sound, its unmistakable
'93 Nissan 240sx
'90 Nissan 240sx - KAE-T? might go NA instead
Old 12-30-2004, 12:29 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
G35Turbo, I'm having the EXACT same problem. I've seen others are too...maybe the cold weather? Anyway, PM me if/when you find out what's wrong so I know where I should look first.
Old 12-30-2004, 11:37 AM
Ok man If I get any Info I tell you.
