Old 12-15-2004, 01:47 PM
kirmml kirmml is offline
TCCM Location on a 2000 Blazer
I have a 2000 2DR Blazer and need to replace the TCCM. I have the NP233 transfer case.
Is the TCCM located under the kick panel on the passenger side? It looks like all I need to do is unplug, unbolt and do the reverse order to install. Is the whole piece the TCCM?
Thanks!
Old 12-15-2004, 03:00 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: TCCM Location on a 2000 Blazer
TCCM?
What is that?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-17-2004, 05:16 AM
ricksza's Avatar
ricksza ricksza is offline
Transfer Case Control Module
Yes that's where it is, but before you replace it, try just unplugging it for about three minutes then plug it back in. It might help.
Old 12-17-2004, 12:46 PM
BlazerLT's Avatar
AF -Advisor
Ah, the electronic encoder motor.
More often than not, the pull the battery trick is only temporary.
The real fix is to replace it.
Old 10-10-2005, 02:57 PM
red94fourdoor red94fourdoor is offline
Send a message via AIM to red94fourdoor
Re: Re: TCCM Location on a 2000 Blazer
Is the encoder motor located in the same place on a 1994 4.3 auto?
Old 10-10-2005, 03:05 PM
maxwedge maxwedge is offline
A990 racer
It's in the transfer case, might also need pcm update with the replacement, lots of TSb's on this.
