Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-15-2004, 02:19 PM
WhiteGST99's Avatar
WhiteGST99 WhiteGST99 is offline
Question Question about 1g/2g turbo engine
Hi guys, one of my friends has just bought a 2g earlier gsx(i don't know if it's a 95 or a 96 but this is not a problem) and he's looking for make a swap with 1g gsx engine.........ok, he know whats he got to do because he has just do a swap but we got a question about the difference between 1g & 2g engine block.
We wanna know if the only one difference is just the head or if also pistons, and the other internals are different and in this case better than the one in the 2gen, because he don't know if make only an head swap, or sawapping all the engine block.
If there are some other differences can you wrote down in this thread please.
thanks a lot
Juventus F.C.
Old 12-16-2004, 03:47 PM
bad4g63 bad4g63 is offline
Re: Question about 1g/2g turbo engine
i do know that youll be losing about 15 hp putting in a first gen engine in a second gen body, and the second gen is a little heavier also. you should just stick with the eng gen engine; use a blow off valve from a first gen cuz theyre not made out of cheap plastic.
Old 12-16-2004, 05:00 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
http://www.darklightning.com/gi/1gvs2g.htm
do the 1g 6bolt swap.
ps. i had a hard time understanding what it was you were trying to ask. please try and edit your post to clean things up a bit. it might help you get better information.
DSM geek
Old 12-17-2004, 05:47 PM
2of9 2of9 is offline
yeah...i'd do the 1g Head swap, cuz of the 6-bolt engine.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-23-2004, 10:53 AM
kjewer1 kjewer1 is offline
AF - Advisor
Mr WhiteGST99 seems to be Italian, so I can see why his wording seems odd Could be wrong though.
You can do the 6 bolt block swap and use either head. Its a pain in the ass to use the 2g head because you have to increase the head bolt holes by 1mm. Its a pain in the ass to use the 1g head beacuse you have to convert the whole cooling system over (not the radiator) to 1g parts. Saying that you will lose 15hp with the swap is incorrect, since no one doing a 6 bolt swap is going to be using all stock components
The 1g block has a different bellhousing pattern, but it is compatible with the 2g tranny, just can't use one bolt. The pistons are 7.8:1 compression vs 2g 8.5:1. The rods in the 6 bolt are stronger, and the crank is different as well (thats where the 6 bolt/7 bolt names come from). The 1g head flows more, but the 2g head may offer better low and midrange power. People have run sick times on BOTH heads after all. The 1g head must be used with the 1g manifold also, and the 1g TB is a good idea. 1g stock cams are slightly better (91-94 turbo only) than stock 2g cams.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-26-2004, 02:04 PM
WhiteGST99's Avatar
Yes Kevin i,m from italy, thats why my enghlish sounds funny, thanks a lot for the explanation
Juventus F.C.
