Old 12-15-2004, 01:08 PM
CORE402's Avatar
CORE402 CORE402 is offline
Holley Question.
This is a question about a 600CFM Holley 4150 with vacuum secondaries. I have a Camaro with a 350 pushing about 10:1 compression, a dual plane manifold, a new crane cam, a 2500+ stall converter, redone TH350 tranny with a shift kit, and 3.73:1 rear end ratio. I was wondering what spring color I should use for the secondaries? I currently have the purple spring in there, but I have been using that same spring since I had the low compression heads, old cam, and 2.73 gears in the back. Now that I have the low rear end gears could I go all the way up to a white spring, the short yellow spring, or the long yellow spring? Any other info that I should know about the carb would be useful too. I know my way around carbs. I was just curious if I could get more ball park before having to go through all the different settings and having to go drive the car to see the results.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 12-15-2004, 03:58 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Re: Holley Question.
Have no idea about yours, but if you know about Holley carbs.... Where in the hell is the "Fast Idle Screw" on the 3310-3 (4150/4160?).
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 12-15-2004, 10:58 PM
CORE402's Avatar
Nevermind. I tested it today. The white spring will go in tomorrow.
1973 Camaro
AFR 195cc heads
TH350
