Old 12-15-2004, 12:50 PM
deadeye deadeye is offline
99 Blazer LS Question
Newbie here. Just bought this vehicle a week ago. 4 door, 55K miles on it, paid $8900. While driving in the dark, I see a quick flicker in the lights, both instrument and headlights. I only drive a half hour to work and I see this flicker just once during the trip. I don’t know if I’d see it again if I drove longer. It occurs about 15 minutes after startup. The flicker is literally just a flicker, not something that hampers vision. Anyone know what might be the cause?
Thanks,
Deadeye
Old 12-15-2004, 04:07 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 99 Blazer LS Question
Nope, no idea, just keep an eye on the voltage guage, it should always be around the 14v mark or just a little above.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-22-2004, 12:45 PM
99BlazerLS 99BlazerLS is offline
I have the same problem with my 99 Blazer. At first I thought it was my eyes playing tricks but it has happened enough that I know it's the lights. Every once in awhile, they will just barely flicker. No idea why, but just wanted to let you know you're not alone
Old 12-22-2004, 12:50 PM
BlazerLT's Avatar
AF -Advisor
Just for my information, does it happen with the defrost on?
Someone told me that the computer will cycle the AC compressor on every once in a while to keep the compressor from seizing up during the winter.
Wonder if that could be causing the flicker.
Old 12-22-2004, 12:55 PM
Mine happens without my defrost on, but the AC has been on. I'll have to watch that.
Old 12-22-2004, 01:36 PM
BlazerLT's Avatar
AF -Advisor
Sometimes the AC compressor kicking on will cause the lights to flicker slightly.
Old 01-06-2005, 08:32 PM
Mine occurs without the defroster on. No fan on at all.
Old 01-06-2005, 08:38 PM
BlazerLT's Avatar
AF -Advisor
yip, because the defrost usuaes you AC system to dehumidify the air.
Old 01-07-2005, 12:32 AM
punkrockdario punkrockdario is offline
i had a problem like that with my 95 jimmy. my headlight switch was bad. got damn hot with the lights on and just started flickering. 20bucks later i had niped it in the butt.
i hope you guys have an easy fix.
Old 01-07-2005, 10:25 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Flickin ahe...
I have a 99 blazer LS and watched for the flicker and noticed it as I was pulling out of my driveway. Just a brief second and it was the defrost/AC compressor coming on as I turned the heater controller to defrost and floor.
Not a big deal, but was wondering and didn't put the compressor in my thoughts until I read this....
Thanks...another mystery cleared up.....
Old 01-07-2005, 10:41 AM
BlazerLT's Avatar
AF -Advisor
Best to only use defrost when you need it.
Using defrost will kill your fuel economy.
Old 01-07-2005, 05:53 PM
Turbocpe Turbocpe is offline
You sure it isn't the ABS system? When the vehicle reaches 3mph for the first time of each new engine start cycle, the ABS computer briefly energies the ABS pump motor as a self-test check.
This will cause a slight draw on the voltage system when the pump kicks on for a second or so.
About using the defrost, you may want to continue to use it, or atleast use it frequently. You want to keep the A/C system's seals lubricated.
Old 01-08-2005, 02:35 PM
BlazerLT's Avatar
AF -Advisor
Yes, as I said, using it only when needed will still run the AC system.
You don't have to run it constantly to keep the AC system running.
Some people keep it there all the time not knowing the drag it puts on the engine and the fuel economy it wastes.
Old 03-10-2005, 01:02 PM
Mr goodwrench said there's some kind of tech report on this but no recall. What we're seeing is a split second draw on the alternator. For $100 or so they'll replace the wiring harness to make the problem go away.
72 MGB - My hobby
05 Envoy - My Pig
05 Corolla - Wife's driver
98 Camry - My driver
Old 03-10-2005, 06:30 PM
Since you never stated, does it occur when you first get the vehicle moving? As I mentioned before, at 3 MPH for the very first time the vehicle is moved upon that engine start, the ABS system will briefly kick on the ABS pump motor as a self-test at 3MPH. This is explained in the shop manual.
I have a '98 LS. At night time when I drive off for the first time after engine start, as soon as the vehicle gets moving, the headlights and interior dash lamps all dim for a split second as this ABS pump motor self-test occurs.
This actually is also something my Ford does, but around 19MPH. It is a common part of the ABS self-test to ensure that the pump and the circuit are working and will work if the driver needs the ABS.
