Old 12-15-2004, 11:26 AM
mrfirebird mrfirebird is offline
cpi/nut kit
i know what the cpi is but what 's the nut kit ?
Old 12-15-2004, 11:51 AM
troubles789 troubles789 is offline
Re: cpi/nut kit
The two internal fuel lines that attach to the cpi and to the drivers side back of the intake.
Old 12-15-2004, 02:12 PM
Skeeter6755 Skeeter6755 is offline
Don't forget that is you are goint to change out the CPI and Nut kit, to get a new gasket for the penulum.
Skeeter6755
Old 12-15-2004, 02:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: cpi/nut kit
yip, what he said. ^^^^^
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-15-2004, 05:03 PM
thanks fellas, haven't had the pleasure of changing that yet, but i keep seeing topics about it and wasn't sure what it was.
Old 12-15-2004, 05:50 PM
BlazerLT's Avatar
AF -Advisor
Re: cpi/nut kit
also, here is my experience with the CPI and injector.
http://www.s10forum.com/forum/showth...pi+replacement
Old 12-21-2004, 07:16 AM
brusk1 brusk1 is offline
Re: cpi/nut kit
I've seen multiples threads on the CPI and Nut Kit. I've been able to locate the CPI at autozone, but am having a hard time locating the Nut Kit/fuel lines. Does anyone know of a OEM part number to reference against?
Here is my problem. 94 s10 blazer 4x4 vin w. Hard starting and rough idle (idle has degraded to point of stalling). Fuel pump, strainer, filter replaced. Looked inside Plenum and some "washing" appears to be occuring.
Old 12-21-2004, 09:55 AM
Mikado14 Mikado14 is offline
Re: Re: cpi/nut kit
The nutkit is a GM only part. Just go into any dealer to their parts counter and tell them your year, engine and that you want a nutkit for in the plenum.
If your washing, you have problems. Passenger side = regulator : Driver's side = nutkit. Sounds like you will be doing the CPI and the nutkit.
Old 12-21-2004, 11:08 AM
Re: cpi/nut kit
Thanks... I may have found at a AC Delco parts store 17112705 and CPI OEM 17113165.
In reading through various posts it came highly recommended to replace both, so that is the my current plan... as well as plugs for possible fouling.
I hope this is the "only" issue as it sounds like a number of folks have had this same issue and more. The only other thing that sounded weird was the IAC idle air control valve... but I believe this to be a symtom of the CPI/leak issues.
Old 12-21-2004, 03:21 PM
BlazerLT's Avatar
AF -Advisor
Re: cpi/nut kit
Best to remove and clean the IAC valve when you are doing all of this.
It gets carboned up.
Old 12-22-2004, 12:03 AM
tom3 tom3 is offline
Re: cpi/nut kit
Best all around deal I found was for new GM parts at www.rockauto.com for the CPI, nut kit, and gasket.
Old 12-22-2004, 08:42 AM
Re: cpi/nut kit
Thanks for the information, but I have already picked them up from Autozone and ACDelco parts supplier. I hope to get it changed this evening.
Old 12-22-2004, 11:46 AM
Re: cpi/nut kit
One thing to watch for. There is a torx head bolt on the rear of the engine that holds the "nut kit" fuel lines in place. This was extremely tight and hard to access on mine. Be sure to have a perfect fitting torx bit and use caution, don't mess up the head.
Old 12-22-2004, 12:17 PM
BlazerLT's Avatar
AF -Advisor
Re: cpi/nut kit
Also, clean the EGR passage when you have the upper plenum cover off. It will be the one right near the intake butterfly that will be choked full of carbon.
Old 12-22-2004, 04:58 PM
Re: cpi/nut kit
I cleaned the EGR passageway in the upper plenum last night. I bought a gasket today for the EGR valve, so I plan on taking it out and cleaning carbon deposits around the valve (recommendations for or against?). My plenum looked similar to BlazerLT's thread on S10.
Blazer, I see your recommendation to remove and clean the IAC. Is there any concern with removing the IAC as a potential vacuum loss path or does reassembly close it up good enough?
Thanks for the TORX comment, I will have to double check I've got the right one.
