Bypassing Egr Valve
I Have A 93 Blazer Lt, 4.3 Vortec. Is There A Way That I Can Bypass The Egr Valve.
Why would you want too...without it working properly you would end up with a check engine light...if you feel the EGR valve in not working try cleaning it first..There's several post in the forum on "how to"...
Re: Bypassing Egr Valve
EGR is part of your engine and is there for a reason. Leave it alone.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Sure you can bypass the EGR valve. Just buy a block off plate from you local speed shop. While you're at it, buy a fresh motor too because the EGR valve is there to cool the combustion chamber so without it, you will hear a lot of pinging until the motor melts.
Yip, leave it alone.
I've bypassed them to diagnose a faulty valve, engine runs fine but the SES light does come on. Gets to be a pain to keep cleaning it but I'd try to leave in operation myself.
It isn't running fine.
Your knock sensors will be detecting ping and retarding your timing therefore killing your power and fuel economy.
You also forgot that a 93 with the check engine lite on will go into open loop = poor fuel milage
Can someone explain why letting hot exhaust gases in is going to cool the combustion chamber? I beleive it is actually just part of the emission system.
'89 S10 Blazer 4.3 V6 4X4 with LOTS of rust. |
if you want it to run cooler then get a EGR gas cooler or make a cutoms one to fit on there. think it uses the existing coolent to cool it. don't know if it works.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system. 71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out. 90 cav, 2.2 tbi, gas getter. 99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed. |
Re: Re: Bypassing Egr Valve
It is like you are saying the smoke is hotter than the fire.
Mikado14
I would agree with everything you said and would add that by lowering the combustion temps that also reduces the chance of piston ping and that alone will help performance |
so does the EGR mod do anything or just nothing at all?
Read this: http://www.autoshop101.com/forms/h61.pdf
